#1 Mazda b200 diff parts wanted
DatsAndy Posted on: 2010/7/29 4:06
We have a rather large mazda (apparently b200 diff) wondering if anyone has any parts or is using one or similar in 1200. After drum brake parts to fit pads to back plate. By the way there a great fit under 1200 (well ute) just gotta move the mounts for leaf springs out a little will give exact measurements when i fit it to Wagon.
#2 Re: Mazda b200 diff parts wanted
Posted on: 2010/7/29 4:42
what stud pattern and pcd are they?
#3 Re: Mazda b200 diff parts wanted
DatsAndy Posted on: 2010/7/29 5:40
Well unless someone has modded it, we have a set of 14 inch pintara stockers that fit it. So its the same as Datsun stud pattern, not sure what PCD but the pintara rims fitted under the guards (In Ute)with like 195/75/14's
#4 Re: Mazda b200 diff parts wanted
benny Posted on: 2010/7/29 6:39
PCD would be 4.5 inch [114.3mm] if the pintara wheels fit.
#5 Re: Mazda b200 diff parts wanted
PIGDOG Posted on: 2010/8/10 14:06
if its a b200 diff it would/should be 6 stud, same diff would be used in mazda vans and such
why do you want drums for it? adapt some disc brakes to it, better braking and less weight
#6 Re: Mazda b200 diff parts wanted
ddgonzal Posted on: 2010/8/11 3:54
My 1994 Mazda B3000 pickup (3.0 liter) has 5-stud wheels.
#7 Re: Mazda b200 diff parts wanted
DatsAndy Posted on: 2010/8/11 6:30
This was out of Mazda b200 (not b2000 or b2200) according to the ebay seller and was in the yellow Ute. datto 14's fit that's all i know, not sure what 4 stud axles or whether they've been re drilled the drums are huge. Yeah was thinking of going disc over the last couple of days actually.
