Mazda b200 diff parts wanted
From Armidale N.S.W
We have a rather large mazda (apparently b200 diff) wondering if anyone has any parts or is using one or similar in 1200. After drum brake parts to fit pads to back plate. By the way there a great fit under 1200 (well ute) just gotta move the mounts for leaf springs out a little will give exact measurements when i fit it to Wagon.
Posted on: 2010/7/29 4:06
Edited by DatsAndy on 2010/7/29 16:00:24
73 1200 wagon SOLD
Re: Mazda b200 diff parts wanted
what stud pattern and pcd are they?
Posted on: 2010/7/29 4:42
From Armidale N.S.W
Well unless someone has modded it, we have a set of 14 inch pintara stockers that fit it. So its the same as Datsun stud pattern, not sure what PCD but the pintara rims fitted under the guards (In Ute)with like 195/75/14's
Posted on: 2010/7/29 5:40
73 1200 wagon SOLD
From Sydney
PCD would be 4.5 inch [114.3mm] if the pintara wheels fit.
Posted on: 2010/7/29 6:39
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Geelong, Vic
if its a b200 diff it would/should be 6 stud, same diff would be used in mazda vans and such
why do you want drums for it? adapt some disc brakes to it, better braking and less weight
Posted on: 2010/8/10 14:06
My 1994 Mazda B3000 pickup (3.0 liter) has 5-stud wheels.
Posted on: 2010/8/11 3:54
From Armidale N.S.W
This was out of Mazda b200 (not b2000 or b2200) according to the ebay seller and was in the yellow Ute. datto 14's fit that's all i know, not sure what 4 stud axles or whether they've been re drilled the drums are huge. Yeah was thinking of going disc over the last couple of days actually.
Posted on: 2010/8/11 6:30
73 1200 wagon SOLD
