« 1 ... 41 42 43 (44) 45 46 47 ... 49 »
Re: Datsun 1200 Sedan Build
From Trinidad and tobago
Yes,If you look closely you could see where we used temperary bolts to keep the disc to the hub.
Posted on: 2014/6/18 22:59
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
From dominican republic
darren i want to know what spark plugs are you using also what specs of jets do you have in your weber what size does your extractor and exhaust have and how many rpm's do you get
thanks. :)
Posted on: 2014/7/15 4:05
thanks. :)
Hey mpower,The spark plugs that i'm using are NGK BP5ES..As for the weber jets are
140-150 Main
185-190 Air corrector
50-55 idle jets
26/27 venturies
F50/F50 Emulsion tubes
Extractors are 4 into 2 into 1 Primary are 1 1/2'' to 2'' to
1 3/4'',exhaust system is 1 3/4''..Never ran this baby Redline but i get alot of power at 6,000 rpm down is i don't have a speedo but a tacho.
Posted on: 2014/8/14 1:40
Street Sleeper!
Update
Did the recent brake mock up with the b14 brakes a few months ago,no success so i put back my b310 struts to drive with.Then i was back at it again,Jacked up the front took off the front wheels started scrapping the goal was to make the s13 fit my 13'' rims,if anyone recalled i had done the s13 before and some pics are in this thred the only problem was the wheels were rubbing the calipers not jamming so we decide that we would do any thing to make them fit into 13 rims even if it's to grind down the calipers to clear i have to make new brackets since the ones i made earlier some one had thrown them away by mistake,So i got fresh 3/8's metal to make em over a few templates is all it needs.Ok SO PICS NOW ^_^
The Rotors will have to be cut down so the pads will fit and wear perfect.
Posted on: 2014/8/14 2:36
Street Sleeper!
thanks darren im asking because of my setup, just built my a12 with 14 piston to .040 making it 1300cc at 77mm bore with worked stock rods for the pin diameter used some double valve springs dont know from what car :P and the h89 a15 head shaved to .080 stock manifolds with a 2 inch exhaust and a honda 1 3/4 silencer also the 32/36 weber carb just that i cant remember my jets :P but they are diferent that yours, electronic custom dizzy and an electric fan the car redlines at 7500 with an awesome power curb.... been beating some d15 vtec honda civics :P stock gearbox and stock but welded diff for more fun and traccion just that i dont have the time and a camera for posting :(
forgot to mention my plugs are bkr6es-11 the gap is 1.1mm and they work really well
Posted on: 2014/8/15 0:18
Posted on: 2014/8/15 0:30
Nice .Do update the thread.
Posted on: 2014/8/15 2:56
Street Sleeper!
Rotors back from the machinist pad area is all good. compared s13 to 120y then mounted them on.
Posted on: 2014/8/15 4:59
Street Sleeper!
i have the s13 turbo brakes in my datsun all arround even the pump :P but didnt machined them all stock well im using stock drum brake struts with custom brackets damn i really need a camera xD
Posted on: 2014/8/16 3:14
What size rims are you using?
Switched the struts from left to right 2day so calipers won't hit steering arms.
Posted on: 2014/8/17 0:58
Street Sleeper!
