Need help with a question!!!
From Trinidad W.I.
Yeah I was just wondering is it possible to super charge an A15 engine without doing any modifications to the engine? All I want is about 3 or 5 lbs of boost Also will it cause any damages to the engine? I want to be able to switch in on when i need it and off when I don't.
Posted on: 2006/3/9 20:35
Re: Need help with a question!!!
From Burbank, CA
all you need is sufficient octane to prevent detonation.
Posted on: 2006/3/9 20:42
|||\ 81 KPB310 /|||
From Bris-Vegas
If you're looking for a better hp gain without too much work, you can go for say a 9-10 psi item & fit a copper head gasket to reduce the compression.
Not too xxey.
Posted on: 2006/3/9 22:44
CA18DET '74 1200 ute project
From portugal
Good question!
i have allready try
Posted on: 2006/3/10 0:46
You don't need to modify the internal parts of the engine if the boost is kept low. See Supercharging and Turbo-supercharging tech section article.
Posted on: 2006/3/11 3:42
