(1) 2 3 4 ... 8 »
Gearbox fill bolt - stuck!
From SE Melbourne
Hey all
Was planning to crack open the gear box (60 series 4 spd) and filll it with transmission fluid.
No matter what I do I can't get the god damn filler bolt of the gear box.
Mental note - next time I fit an engine I'll make sure this bolt turns easy....but any ideas now the motor is in?
Posted on: 2006/8/5 6:43
Mildman, Datsunless
Re: Gearbox fill bolt - stuck!
From Inner west nsw CAMDEN
dude jack it up and put a pipe or extension on it add some heat around the case an that should do it, same problem with my cousins 1200 ute
Posted on: 2006/8/5 6:48
FAT 120Y SR20de-NOS
What speed are you doing at M kmh???
Bet my bonnet scoop is bigger than YOURS!
Do wheelie bars suit a street car?
i've heard of people putting an extension on it, then using the cars weight to undo the bolt.
I put a braker bar on mine and used my feet to push it (making sure the car was securly jacked up). Even after a couple of turns i still had to use feet!!! i have no idea why they are always so tight, its usually realised when the box is in too :)
Posted on: 2006/8/5 8:35
From Sydney
i had this problem in my mates 1600 and the plug was rounded so i put a nut over it then welded it on and then i undid very easily
(i had a spare filler plug to replace it with)
but maybe in your case it just needs more leverage a bit of pipe or a 18inch shifter
Posted on: 2006/8/5 9:03
From Brisbane, Narangba
Hammer and spanner. Shock force is great at realeasing tight bolts. Puts less stress on the bolt and thread too. Dont go overboard. once the seal so to speak is cracked the bolt will move.
Posted on: 2006/8/5 9:04
From Sydney , NSW
Dude,
flick the girly spanner Grab the big shifter and have a go!! Gearbox uses a tapered plug and the steel plug likes to hold on to the alloy housing. I have never had a disaster with these plugs - I personally wouldn't use heat but to each his own. A hint if the box is out of the car ..... lay the box down and use the weight of the box to your advantage. If you have it standing on end, it will easily want to topple and half your effort will be in pushing against yourself to hold it upright.Hope this helps.
Cheers
Posted on: 2006/8/5 9:12
R-fastmotorsport wrote:
Dude,
I'll second that motion. Get something that will get a bloody good grip on as much of that square section as possible, & within reason, the bigger the better. I have been known to use a F.B. shifter, & if that doesnt work, then I have seen a Stilsen wrench called into duty. It ruined the plug, but it's just a consumeable anyway & another was used to replace it.
It's a bit like masturbation, you gotta get a good grip on it.
Posted on: 2006/8/5 9:26
Love your Datsun.
Treat it well.
get a better wrech and while your there mildman... fix that damn rust in the floor before it gets worse!
Posted on: 2006/8/5 10:18
From Christchurch
If your not worried about wrecking the bolt. Stilsens/pipe wrench/plumbers wrench (whatever you want to call them) work really well (they have jagged teeth on the jaws). i used to use these when i used to do wheel alignments you can get absolutely anything undone with them with a bit of crc and a long enough bar for a bit a leverage :)
Nick
Posted on: 2006/8/5 10:29
From SE Melbourne
Went and bought some steel pipe - if I get time before the cruise in the morn I'll stick the pipe on the end of my big arse shifter and have some fun.
Posted on: 2006/8/5 11:20
Mildman, Datsunless
(1) 2 3 4 ... 8 »
