« 1 (2)
Re: What Shocks?!
From Brisbane
wet kit, as in oil, not a gas insert? like forks on a motorbike, no way you can put 2/3 oil in a strut then try and install a gas insert.
Posted on: 2007/6/18 10:10
Re: What Shocks?!
From Sydney
lol no no 2/3's the way up with the strut installed so only like 50m's or watever. Its just normal installtion method for regular insterts. remeber gas insert still use oil as per normal ones theres just gas in them aswell(insted or air) so the oil dosent bubble up as easy.
Posted on: 2007/6/18 10:16
Re: What Shocks?!
From Adelaide, Australia
Inserts can be gas charged or oil, or oil with gas assist.
With my konis, which are oil inserts, I put 150ml coolant in with the insert to help with heat transfer.
Posted on: 2007/6/18 10:17
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: What Shocks?!
From Brisbane
150ml, do you have short inserts in your strut?
Posted on: 2007/6/18 10:31
« 1 (2)
