#1 need help with E15ET/120y Gearbox startermotor problem
Matto1kUte Posted on: 2008/2/9 12:09
hey guys just got a major prob with my E15ET in datto1000 ute conversion. i cant seem to find a starter motor that will fit and work. the a series one fits but jams up (teeth dont line up) if i use a stock e15 starter it turns the motor backwards and a E15ET starter mouts on top of the gearbox. the closest one is a n14/n15 starter motor. it bolts up but doesnt connect with ring gear on flywheel. nothing else fits. has anybody done this or can anyone help. its all waiting to go all i need now is to be able to turn it over. please help :(
#2 Re: need help with E15ET/120y Gearbox startermotor problem
pepper Posted on: 2008/2/9 12:52
is there any possibilty of swapping the E gear with the A gear, or maybe modify the E starter to spin the other way?
#3 Re: need help with E15ET/120y Gearbox startermotor problem
dattodude Posted on: 2008/2/9 13:27
Could the E15 starter motor can be reassembled so it spins the right way?
From memory, I remember with radio control cars, we just pulled the end bell off and rotated it 180 degrees.
I'm not sure about this, and I no longer have any removable endbell DC motors (RS-540) to test this purely 'from my memory' theory.
#4 Re: need help with E15ET/120y Gearbox startermotor problem
dattoman_1000 Posted on: 2008/2/9 14:31
Wow
It doesn't bolt straight in ?
Unbelievable
Maybe a reverse rewind is needed
#5 Re: need help with E15ET/120y Gearbox startermotor problem
cheater_5 Posted on: 2008/2/9 19:52
new ring gear on flywheel so a sereis motor meshes???
#6 Re: need help with E15ET/120y Gearbox startermotor problem
Ronald Posted on: 2008/2/9 23:10
i would swap the A series bendix drive with an E series one, so that u can use the A series starter motor and have a drive that fits.
#7 Re: need help with E15ET/120y Gearbox startermotor problem
B210sleeper Posted on: 2008/2/10 1:31
making the one that turns the wrong way work would certainly be the easiest.
changing the drive gear to match the flywheel of one that fits and turns the right way, but grinds would be the second easiest.
re-toothing the flywheel seems like a lot of work.
#8 Re: need help with E15ET/120y Gearbox startermotor problem
carjunkie Posted on: 2008/2/10 2:39
Could it be possible to slot one of the starter bolt holes so you can adjust the depth that the starter gear is meshed with the ring gear?
#9 Re: need help with E15ET/120y Gearbox startermotor problem
ddgonzal Posted on: 2008/2/10 4:36
Are you using the A-series flywheel or E-series flywheel? Maybe they just need to be swapped. Or maybe using a fwd flywheel will work.
#10 Re: need help with E15ET/120y Gearbox startermotor problem
mikeys_toy Posted on: 2008/2/11 3:35
please excuse my ignorance, but you can use an e engine in an a car?
