need help with E15ET/120y Gearbox startermotor problem
From Adelaide, Australia
hey guys just got a major prob with my E15ET in datto1000 ute conversion. i cant seem to find a starter motor that will fit and work. the a series one fits but jams up (teeth dont line up) if i use a stock e15 starter it turns the motor backwards and a E15ET starter mouts on top of the gearbox. the closest one is a n14/n15 starter motor. it bolts up but doesnt connect with ring gear on flywheel. nothing else fits. has anybody done this or can anyone help. its all waiting to go all i need now is to be able to turn it over. please help :(
Posted on: 2008/2/9 12:09
Re: need help with E15ET/120y Gearbox startermotor problem
From Tamworth , NSW
is there any possibilty of swapping the E gear with the A gear, or maybe modify the E starter to spin the other way?
Posted on: 2008/2/9 12:52
From Sydney, Australia
Could the E15 starter motor can be reassembled so it spins the right way?
From memory, I remember with radio control cars, we just pulled the end bell off and rotated it 180 degrees.
I'm not sure about this, and I no longer have any removable endbell DC motors (RS-540) to test this purely 'from my memory' theory.
Posted on: 2008/2/9 13:27
From Perth
Wow
It doesn't bolt straight in ?
Unbelievable
Maybe a reverse rewind is needed
Posted on: 2008/2/9 14:31
From The garage, NZ
new ring gear on flywheel so a sereis motor meshes???
Posted on: 2008/2/9 19:52
From Bendigo, Victoria, Australia.
i would swap the A series bendix drive with an E series one, so that u can use the A series starter motor and have a drive that fits.
Posted on: 2008/2/9 23:10
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Burbank, CA
making the one that turns the wrong way work would certainly be the easiest.
changing the drive gear to match the flywheel of one that fits and turns the right way, but grinds would be the second easiest.
re-toothing the flywheel seems like a lot of work.
Posted on: 2008/2/10 1:31
|||\ 81 KPB310 /|||
From brisbane, qld
Could it be possible to slot one of the starter bolt holes so you can adjust the depth that the starter gear is meshed with the ring gear?
Posted on: 2008/2/10 2:39
Are you using the A-series flywheel or E-series flywheel? Maybe they just need to be swapped. Or maybe using a fwd flywheel will work.
Posted on: 2008/2/10 4:36
From Monroe, wa, usa
please excuse my ignorance, but you can use an e engine in an a car?
Posted on: 2008/2/11 3:35
NAPA parts bitch
