« 1 2 (3)
Re: here we go again...Brakes
From Millgrove Vic OZ
Z struts have a different stub axle angle. In the Z they get the camber right by setting the towers closer together.
They give lots of positive camber using them in stock strut mounts.
I havent encountered any Z struts with a wider bolt spacing onto the steering arm
L18-B110 do you know which model uses a wider bolt spacing?
When it comes to brakes on stanza struts the cheapest and most effective bolt up brake conversion is the 270mm 240K disc with sumitomo 2 spot calipers. This combination can be used with 13" rims
Posted on: 2003/6/14 23:30
Cheers Feral
Hey feral are you sure you can use the 270mm rotors with the sumi's on a stanza strunt:? because I have that same setup but with only the 253mm rotors and they don't have a lot of clearance?
Posted on: 2003/6/15 5:58
From Charlotte NC USA
I have the 510(1600) crossmember this sets the wheels out 10mm and the z struts reset the camber close to stock
Posted on: 2003/6/15 7:51
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
Nutcase, your B210 is wider, and so the 510 crossmember fits. The B110 is narrower and doesn't fit without modification.
Posted on: 2003/6/15 8:40
yup but the b310/210 (out of a 1981 210) controll arms that we put on my brothers 110 made it almost 1/2" wider and the camber went wild so we are thinking of the same swap in his as well
Oh yeah my datsun guru said the 510 x-member bolts into the 110 as well for the pb110 Excelent he should know he's done 3 of em'
Posted on: 2003/6/15 10:36
Phil (aka nutcase)
I have C.L.W.E.A.
From Melbourne, Australia
i know ya can get a 120y crossmember into a 1200 with some modification, so im guessing if the 510 one goes straight into your 120y??? you have to modify it for a 1200
Posted on: 2003/6/15 11:02
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Sorry about that it should have read late 240K struts.
I will measure up some stanza/200B struts with this combo when I get some time.
Posted on: 2003/6/15 15:08
Cheers Feral
From Brisbane, Australia
Feral, The struts I've got with the wider bolt spacing are out of a 260Z 2+2. So I assumed all Z cars must use that wider spacing? I might go and measure them tonight.
Posted on: 2003/6/16 2:05
« 1 2 (3)
