(1) 2 3 »
what has the same axel as a h165
From Adelaide, Australia
i was thinking of locking my h165 but im scared of snapping an axel cause i think would be hard to come by. is there any other axel that will fit, like out of another diff and has anyone had this problem with a h165
Posted on: 2003/6/15 10:56
Datsun
Re: what has the same axel as a h165
From Melbourne, Australia
if yor talking about a ute h165 there isnt one, if your talking bluey h165 then there is a million blueys
im guessing you mean a ute one though, the axels are quite rare and if ya think ya gonna break one maybe you should put a vanette h190 diff with fwd offset rims or flares in
Posted on: 2003/6/15 11:08
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Okinawa, Japan
I was talking to one of my buddies and he said the utes here may have the same diffs as the passenger cars. Is there an easy way to identify if my truck's got a 165 or not?
Posted on: 2003/6/15 13:21
h165 in a coupe
i did measure the centre once but cant remember how big it was
there was quite a diffrence between the 165 and 145 and you should be able to see it visually, maybe you can tell from this pic if yours is the same or smaller?
otherwise i can measure it tomorow for ya (too cold and parked on stones at the moment)
Posted on: 2003/6/15 13:26
1200 Coupe Rallycar
From Okinawa, Japan
Yeah I looked at that picture but it's hard to see much. It's dark and pouring out right now so I'll measure mine up tomorrow.
Posted on: 2003/6/15 13:31
one diffrence i remember now is that where the brake line splits to each side via a "t" piece, on the h145 there was a bolt that went through the t-piece to mount it to the diff, on the h165 there was not
Posted on: 2003/6/15 13:41
1200 Coupe Rallycar
Also if you have a U bolt that holds the diff to the leaf springs from an H145 it won't fit around the H165, not sure if that is any help?
Posted on: 2003/6/15 14:55
actually i got mine to fit with a bit of strecthing and bashing with a hammer, i also used the base plates off a h145 with elongated holes
Posted on: 2003/6/15 15:03
1200 Coupe Rallycar
From Melbourne AUS
RC apparently the H145 has studs with nuts holding the centre in... and the H165 has bolts holding the centre in? can you comment on that since you have both?
Posted on: 2003/6/15 15:10
1973 B110 A12
um, i read that, im not really sure cause all i ever did with the h145 was take it out and its gone now, i dont think this is true but could be wrong
feral???
edit - just remembered i still have a h145 on the 2dr sedan, lol, cant get away from them, but again i havent really looked at that sorry
Posted on: 2003/6/15 15:13
1200 Coupe Rallycar
(1) 2 3 »
