« 1 2 (3) 4 5 »
Re: help req for sc14 supercharger setup
From Christchurch NZ
Chances are the oil is still in there. It's supposed to last the life of the supercharger. You'll see on the back end (opposite the pulley end) There are a couple of bungs. One in the bottom, and one in the side. The bottom one is a drain, the side one has a dipstick on the bottom of it. The S/C12 off the 4AG-ZE has a yellow wingnut on the dip/fill bung, whereas the S/C14 just has a bolt hex on it. The oil is usually bought from toyota. It costs more than 30 year old scotch. They only take about 130 odd mls. Just unscrew your fill bung (With the blower vertical, IE over and under, rather than side by side) and see how much oil is on the dipstick. If you find that your blower is using oil, it's time to find a new blower. I've never heard of anyone rebuildoing one of there units. I'm not saying it can't be done, just that I don't know anyone who has.......
Posted on: 2008/10/10 20:39
Forced Induction!
wat sort of motor work should i be lookin at to run this setup nice?? i have bought a a15 lo comp head and just would like to no wat i should do to it and also wat to do to the bottom end, not sure wat bottom end im gonna use a14/a15 gotta sum up wat is better. also wat would be a better carbi to run for draw through to make a good amount of power and good boost. domt want to spend too much cos savin 4 ca...... but wont it reliable for 2 years and to go hard b4 i have enough to do my hot ca conver
ta nick
Posted on: 2008/10/11 10:57
Car free
From Brisvegas, oz
low comp and boost dont go together, it makes baby go boom boom
edit: stupid me.... your right low comp is good high comp is very bad. should think about things longer before i right crap.
Posted on: 2008/10/11 12:14
www.camerasplus.com.au
From Tamworth , NSW
isnt it better to have a lower comp ratio?
Posted on: 2008/10/11 12:21
From Freo
We run redline gear oil in the drive cases on the Sprintex blower drive cases.... oil level is critical, too little and they lunch the gears, too much, same deal... the little helical gears don't like the heat at the rpm they do....
ps the engine this came off had de-comp in the head and andwater-meth injection...
Posted on: 2008/10/11 13:02
A15 PSI Project Motor
'72 CB750k,
Boith ACL, and Permaseal make an off the shelf "head saver shim". They are intended to be used when a head has been skimmed so far that the CR/valve clearance is outside usable tolerances. You glue the shim to the block deck with copper head gasket cement. I run one of these, as well as lower comp pistons. (But not much lower, don't ask about these ) It doesn't hurt to run double valve springs either. You can really get carried away with beefing up the motor, but if you're going to go CA, don't get too hung up with it. If the manifold is for a 32/36, just run with that. They work fine. Do you have the crank puley? What diameter is it? I think the blower pulleys are 125mm from memory. One you get it all running, You'll need to frig arounf rejetting the carb a bit. I ran my mixtures really fat in trepidation of detonation. Just check your plugs to guess the jetting, or if you can borrow one use a wideband A/F meter.
and for the love of god, LISTEN TO YOUR ENGINE!!!!!! If you hear it ping, retard the timing. Don't just drive it hard cos it goes hard. There are UMPTEEN stories on this site starting off got my turbo/blown motor going. Then What causes blowby? lots of folk crack their ring lands, and get mad blowby.
Get your set up running first though.
Posted on: 2008/10/11 21:53
Forced Induction!
Re: help req for sc14 supercharged, motor, and exhaust setup
thanks for the info, i also have to get an exhaust put on the sucker for roady but dont want to have to buy 2, i want to get a exhaust that will be ok for roady on an a12 wit 1x 40mm delorto, but want it to be really setup for the a14 bottom, a15 locomp head and the rest of the work that will be done to the motor. can anyone send me in the right direction of wat to ask for or who to goto please!!
thanks people for your help
Posted on: 2008/10/12 6:39
Car free
bump
want to get exhaust done in the new week any sugests on wat i can go
Posted on: 2008/10/13 1:17
Car free
See if a set of extractors willl clear the blower set up. Since you are forcing the charge in, it's good to make the exhaust side as un restrictive as possible. I made my blower mounts to clear my headers. It was a mission!
Posted on: 2008/10/13 8:57
Forced Induction!
its got extractors lukey ones, not sure if these are any good. ive got pacemaker manderal bent one on my work car and they good. dont no wat size exhaust to put on 2inch or bigger ????
Posted on: 2008/10/13 9:11
Car free
« 1 2 (3) 4 5 »
