Re: Need some info
From Snohomish, WA USA
I'm not so concerned about gear ratios, I'm more concerned about using an axle that is only 2 mm larger in diameter than the one I just broke. If someone has axle diameter chart to share, that would be great. My axle is out of a roadster and I would like to know if all H190's are the same. It has the 10 hole center diff pattern but I thought the axle would be a lot bigger. Oh, I forgot, it only has 23 splines on the axles. That I don't understand.
Posted on: 2010/3/23 4:21
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Subject Poster Date
     Need some info datsa73 2010/3/22 20:33
       Re: Need some info b310gx 2010/3/22 22:07
         Re: Need some info ddgonzal 2010/3/23 0:23
           Re: Need some info datsa73 2010/3/23 4:21
             Re: Need some info ddgonzal 2010/3/23 5:44
               Re: Need some info datsa73 2010/3/23 6:35
       Re: Need some info Anonymous 2010/3/24 20:39
         Re: Need some info datsa73 2010/3/25 2:15
           Re: Need some info PIGDOG 2010/3/25 2:26
             Re: Need some info datsa73 2010/3/25 3:21
               Re: Need some info ddgonzal 2010/3/25 4:36
                 Re: Need some info datsa73 2010/3/25 4:45
                   Re: Need some info ddgonzal 2010/3/25 5:25
       Re: Need some info A14force 2010/3/25 6:25
         Re: Need some info ddgonzal 2010/3/25 6:31
           Re: Need some info lamb_daiquiri 2010/3/25 6:56
             Re: Need some info datsa73 2010/3/25 23:51
               Re: Need some info datsa73 2010/3/27 17:32
               Re: Need some info datsa73 2010/3/28 22:26
                 Re: Need some info datsa73 2010/4/1 2:29
