trouble fitting 40mm dhla dellorto
From adelaide hills
went to bolt it up last night and need about 60mm more room inbetween the head and strut tower. Carbys on a redline manifold which meausures 120mm from face to face.
Has anyone run this setup before and how did you make it all fit? Any help?
Posted on: 2011/6/23 4:46
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: trouble fitting 40mm dhla dellorto
From mandurah
are you running stacks ,or are the carbys hitting the towers ? maybe take some pics to show where its hitting
Posted on: 2011/6/23 5:26
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Near Bundaberg QLD
Might have to use short ram tubes and soft socks instead of a large paper element air cleaner
Posted on: 2011/6/23 10:55
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
From adelaide hills
the carby only has the base plate for a panel filter and would be resting (or very close to) on the strut tower, so theres no room even for short ram tubes.
the guy that was going to help jet and tune it suggested cut a notch out of the strut tower and box it in ( not a fan of that ) or get the manifold customized. which sounds more reasonable
Posted on: 2011/6/24 3:05
Buy another and go twins.
Posted on: 2011/6/24 3:08
From mandurah
Also some pics would help us see what is hitting
Posted on: 2011/6/24 7:02
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
You have the wrong manifold. Here's Dellorto 40s on a Datsun 1200 (using a more appropriate manifold):
Posted on: 2011/6/24 7:55
He only has the one carb. It's the single sidedraft redline manifold.
I didn't think they were THAT long. Pretty sure the bprojects manifold is deeper than 120mm and they still manage to fit.
EDIT: Bpro manifold is about 110mm maybe less. Still clears on datsun B120 with the socks crushed down a little, trumpets clear fine. Sounds like your manifold comes out much further than 120mm Rhys?
Posted on: 2011/6/24 7:59
From Freo
the redline twins for roundport is pretty long...
Posted on: 2011/6/24 8:15
A15 PSI Project Motor
'72 CB750k,
From adelaide hills
dont have any pics at the moment, carb isnt in my hands at the moment.
might have to go twins chris, dan said he'd sell me a oval port head so that might be the go ;)
Posted on: 2011/6/24 8:54
