#1 5-speed reverse solinoid
ratsun_a14 Posted on: 2011/7/28 9:29
utee is almost ready for rego, but i'm having problem with the reverse lights, the solinoid for the 5 speed gear box hits on the tunnel so i blocked it off with a bolt. I was wondering if there is any way to connect it up without to much hassle?
#2 Re: 5-speed reverse solinoid
levey Posted on: 2011/7/28 9:58
There are a few ways around this problem, you could check out my build thread or unfamilias thread for a neater option and there's weekend1000 who solved the problem on a 5spd box.
#3 Re: 5-speed reverse solinoid
levey Posted on: 2011/7/28 10:06
#4 Re: 5-speed reverse solinoid
ratsun_a14 Posted on: 2011/7/28 10:20
nah thats alright! it's simple and i bet it works a treat! did it pass rego alright? did u get that switch from dicksmiths? or 'superheap auto'?
#5 Re: 5-speed reverse solinoid
levey Posted on: 2011/7/28 10:26
This switch came with my aftermarket washer tank setup and have been told its OK for rego as long as it works, the switch will be hidden by the gearbox boot anyway so they wont know :)
#6 Re: 5-speed reverse solinoid
ratsun_a14 Posted on: 2011/7/28 10:27
i should have added that i have a dogleg 5speed(i think thats what its called? reverse is away and up) that switch would have to be in a diffwerent spot
#7 Re: 5-speed reverse solinoid
levey Posted on: 2011/7/28 10:45
Ooops thats an old picture, I now have a dogleg aswell so have changed the location of the switch, might be a pic in my photo albumn.
Just make sure the switch you use is a "momentary switch" (only stays on when pressed)
#8 Re: 5-speed reverse solinoid
Posted on: 2011/7/28 11:00
Check my build thread, worked out a neater solution finally and engineer signed off on it for rwc. I did same as levey and he didn't like it.
Pg 48
Got my switch from dick smith, I went in for dic and got 2 switches instead
#9 Re: 5-speed reverse solinoid
ratsun_a14 Posted on: 2011/7/28 11:15
now thats cool! what type of switch is that? how hard is it to wire it up? does it just hook up to the existing reverse switch wires?
#10 Re: 5-speed reverse solinoid
levey Posted on: 2011/7/28 11:18
I did mention that your setup was neater Mik,
Mines better though :)
