5-speed reverse solinoid
From sydney
utee is almost ready for rego, but i'm having problem with the reverse lights, the solinoid for the 5 speed gear box hits on the tunnel so i blocked it off with a bolt. I was wondering if there is any way to connect it up without to much hassle?
Posted on: 2011/7/28 9:29
Re: 5-speed reverse solinoid
From Perth WA AUS
There are a few ways around this problem, you could check out my build thread or unfamilias thread for a neater option and there's weekend1000 who solved the problem on a 5spd box.
Posted on: 2011/7/28 9:58
Datsun 1200 2Dr sedan.
From Perth WA AUS
Posted on: 2011/7/28 10:06
From sydney
nah thats alright! it's simple and i bet it works a treat! did it pass rego alright? did u get that switch from dicksmiths? or 'superheap auto'?
Posted on: 2011/7/28 10:20
From Perth WA AUS
This switch came with my aftermarket washer tank setup and have been told its OK for rego as long as it works, the switch will be hidden by the gearbox boot anyway so they wont know :)
Posted on: 2011/7/28 10:26
From sydney
i should have added that i have a dogleg 5speed(i think thats what its called? reverse is away and up) that switch would have to be in a diffwerent spot
Posted on: 2011/7/28 10:27
From Perth WA AUS
Ooops thats an old picture, I now have a dogleg aswell so have changed the location of the switch, might be a pic in my photo albumn.
Just make sure the switch you use is a "momentary switch" (only stays on when pressed)
Posted on: 2011/7/28 10:45
Check my build thread, worked out a neater solution finally and engineer signed off on it for rwc. I did same as levey and he didn't like it.
Pg 48
Got my switch from dick smith, I went in for dic and got 2 switches instead
Posted on: 2011/7/28 11:00
From sydney
now thats cool! what type of switch is that? how hard is it to wire it up? does it just hook up to the existing reverse switch wires?
Posted on: 2011/7/28 11:15
From Perth WA AUS
I did mention that your setup was neater Mik,
Mines better though :)
Posted on: 2011/7/28 11:18
