Tunnel tips
Hi,
Im going to attempt widening my tunnel. I bought the maddat tunnel and im wondering if anyone has tips for installing the new tunnel. If anyone has engineer approval for doing it what were the requirements?
Cheers
Posted on: 2011/8/15 4:57
Re: Tunnel tips
20 to 25mm overlap all round
Posted on: 2011/8/15 5:10
Re: Tunnel tips
From Rosewood, QLD
mik is good with man tunnels
Posted on: 2011/8/15 8:27
1971 B110 sedan project.
2012 Nissan Micra daily.
Re: Tunnel tips
From MOOROODUC. Victoria
My engineer said :
". Tunnel welding - Preference for spot welding but will accept 'chain' welding (1 inch welding 1.5 inches space between welds) welding to be on both sides of tunnel (top and underneath). "
you can have a look in my build thread (DEMAC's 1200 UTE)
Posted on: 2011/8/15 8:43
Re: Tunnel tips
I lubed yours up nice and proper ziggy, yours warped from friction burns though.
I used same engineer demacoz. He prefered the spot weld method with mastic in between to prevent rusting.
Posted on: 2011/8/15 9:23
Re: Tunnel tips
From Rosewood, QLD
im suprised you got past the fish hooks and barbed wire
Posted on: 2011/8/15 9:33
Re: Tunnel tips
I know you army guys are kinky, I was ready with my thermal lance
Posted on: 2011/8/15 9:35
Re: Tunnel tips
From Perth WA AUS
So I assume rust repair sections should be welded the same?
Can you do a continuous weld around a repair section on one side only?
I might have to do some more welding :)
Posted on: 2011/8/15 10:17
Datsun 1200 2Dr sedan.
Re: Tunnel tips
What rust repairs, that's factory
Posted on: 2011/8/15 10:22
