#1 urgent turn signal part id
randoli Posted on: 2012/6/19 8:03
i was just disconnecting the turn signal assembly in order to remove in prep for installing a new steering column busch when this part fell out.
what is it and more importantly where does it go??
jpg  P1010629.JPG (28.11 KB)
10135_4fe0241a6fb45.jpg 267X200 px
#2 Re: urgent turn signal part id
loosekid Posted on: 2012/6/19 8:22
http://www.ebay.com.au/itm/SWITCH-COM ... ories&hash=item3365cc39e1
IT looks like it could be off the connector which would be under the dash.. hard to tell
That's if it is part of the turn signal switch or unit :S
#3 Re: urgent turn signal part id
loosekid Posted on: 2012/6/19 8:23
The part connected under the Dash?? other wise have a look at that link to ebay and see if u can notice the part in which it is actually missing off the turn signal switch
jpg  20092281604.jpg (20.86 KB)
16063_4fe02909658f3.jpg 400X256 px
#4 Re: urgent turn signal part id
loosekid Posted on: 2012/6/19 8:28
http://datsun1200.com/modules/mediawi ... ex.php?title=Turn_Signals
Otherwise have a quick look here to see if u might notice it.
#5 Re: urgent turn signal part id
randoli Posted on: 2012/6/19 8:31
yeah cheers, shouldve mentioned id already looked at techwiki. can't see it there.
any other ideas?
it came out after i loosened the wiring on the stalk side. now the stalk is hanging limp.
#6 Re: urgent turn signal part id
randoli Posted on: 2012/6/19 9:00
i've found where it goes. hard to describe. in behind the wiring on the opposite side to the stalk. slides in a slot and serves as some kind of contact.
one prob solved. now no indicators!
help
#7 Re: urgent turn signal part id
levey Posted on: 2012/6/19 9:02
Might be time for a new unit?
#8 Re: urgent turn signal part id
randoli Posted on: 2012/6/19 9:24
was working fine before i decided to pull it apart. just got to double check a few things i guess
