« 1 (2)
Re: sss stanza L series 63a gear box.
Need to jugs to jiggle for $...
Posted on: 2012/8/7 14:23
Oh and if someone was inclined they could try a cut and shut. IM,not sure of input shaft spline though
Posted on: 2012/8/7 14:24
use stanza clutch plate or spline change on clutch plate
Posted on: 2012/8/7 23:55
24 tooth spline I think from memory not sure,on a series. Was more concerned on spigot bush Size. Small stanza clutch us same Size as a series. It wide definitely need to be some one skilled to jig and tig the cut and shut.
Once you've done one easy to split case and swap them in future then. Not as easy as71 but 63 should've strong enough for most a series
Posted on: 2012/8/8 2:11
Sold payment and pick up pending
Posted on: 2012/8/9 13:48
« 1 (2)
