« 1 ... 9 10 11 (12) 13 14 15 ... 20 »
Re: rocketrod's 1200
From Nyngan, nsw Australia
thanks alot Dav i've also noticed where those other two pipes go to,(charcoal canister) cheers!
Andy i also tried that site i don't understand they had #OOPS# loads of goodies, well represented...
maybe having troubles with there listings
yeah sure fella's keep the pics rolling in, more help tha better.....
Posted on: 2012/10/17 9:04
living is good,.....
couple extra i grab
Posted on: 2012/10/17 9:18
Posted on: 2012/10/18 1:01
fitting custom heater piping
Posted on: 2012/10/19 6:08
as notice that electronic CA18 speedo gear drive is bigger than manual drive, whats the best solution to get this working, using the original 1200 cluster running 14" wheels
Posted on: 2012/11/6 5:26
Any come back on question at hand.....or would it be easy to use siliva cluster.
Posted on: 2012/11/6 10:40
From MOOROODUC. Victoria
Certainly NOT easy to use silvia cluster
I ended up using the cluster because of the fuel pump in the R31 tank and the speedo... but have the whole loom on the ute
I collecting all the part I managed to source almost everything from separate cars - Motor, loom, Auto g'box, fuel tank, cluster,
The easy way might have been to get a g'box with a cable to run the speedo, rather than electronic
Posted on: 2012/11/6 21:51
Rod, Just wondering what you made the heater pipes from. Is it copper pipe or steel tubing?
Posted on: 2012/11/6 22:50
From sydney,NSW
just wondering did u buy the chrome grill pieces or did u get them made...?
Posted on: 2012/11/7 5:22
demacoz
i have a maddat speedo cable, just the drive im concerned about, think maybe it would be just easy to fit S13 gauge cluster, little more home work on that, i have the full S13 body & engine loom il get the lecky to sort that out.
cadet1200
i just made from steel tubing, copper would be good to use,
dat_lover
i think your talking about the cowling grill in front of the screen, i had them chromed, was going to paint but chrome looks way better, look great up against the dark color.
Posted on: 2012/11/7 5:48
