Datsun 1200 ute door latch?
Quite a regular
From gold coast, qld
hey im looking to replace my right and left hand door locks, as in the parts inside the door that lock when you turn the key..for some reason my left side wont lock with the key..it only turns a little..any way does anybody know any where i can get these from? or if i can take them out and put central locking ones in or anything ? thanks for any help
Posted on: 2013/1/23 11:09
Re: Datsun 1200 ute door latch?
It won't help to replace the lock. It is the rod that is bent. This happened to me, and straigtening out fixed it.
Posted on: 2013/1/23 11:53
Quite a regular
oh really!!!!! thanks so much man ...which rod is it? i know thats going to be difficult... thanks so much
Posted on: 2013/1/23 12:20
From Brisbane, QLD
I'm assuming he means the vertical rod that goes from Key barrel down to the latch mechanism.
Posted on: 2013/1/23 12:22
71 B110
Quite a regular
ok..so just straighten that one out ..seems to simple to be true haha
Posted on: 2013/1/23 12:24
Quite a regular
by which rod i mean is it the one going to the key cylinder or the rod that goes up and out and becomes the lock that you see up top
Posted on: 2013/1/23 12:27
From Brisbane, QLD
One going to the key cylinder pretty sure.
Double check with ddgonzal though Haha
Posted on: 2013/1/23 12:54
71 B110
Quite a regular
haha alright thanks man
Posted on: 2013/1/23 13:07
Quite a regular
hoipefully he replies ..
Posted on: 2013/1/23 13:08
Mine was bent and couldn't lock/unlock with the key, or even push-knob.
Snap the rod off the lock cylinder, then see if it freely moves. If it does, the lock cylinder is not the problem.
Posted on: 2013/1/23 20:53
