Need help
From vic
Hey i got a new 120y and it came with spares i realised the dash lights
Dont work and that alternator lights on
So i went to change the alternator and i find near the batter an 6 pin female flat connector connected to nothing
In the box of spares there is a big module thing with same connection but male and it fits it
But i dont know what it is it says
Temp. Compensated and has hitachi symbol
Says 12v 609 and tl1z-57c
But i cant find were it would mount on the engine bay
Anyone know what it is?
Sorry cant upload pics via phone
Also that flat 6 pin female connector in engine bay were shuld it go my other 120y dant have it
This is 74 model my other one is 77 australian built while this is jap
Thanks
Posted on: 2013/2/24 2:06
Re: Need help
From vic
okay just figured its a voltage regulator probably why alternator wasnt charging
can i change to a alternator with inbuilt regulator?
Posted on: 2013/2/24 2:18
Re: Need help
Yes you are correct it is a voltage regulator. You will need to determine whether the alternator fitted has an inbuilt regulator or not (it may have been changed at some point and thats why regulator was not fitted).
If not and you want to replace it with a in-built regulator model this can be done. Refer to the tech wiki for detailed information (or I know in the Datsun 1200 Service manual it shows wiring variations for with and without inbuilt regs.)
Posted on: 2013/2/24 2:44
Re: Need help
> the dash lights Dont work and that alternator lights on
Dash lights should still work even if the alternator is not charging. Sounds like you have two separate problems.
1974 B210, japan built or otherwise, used external voltage regulator. Like cadet said it's possible someone swapped a newer internally regulated model, and also possible that it's not wired correctly.
* Look on the alternator for model number
* Alternator T-connector markings of F and N
* Alternator T-connector markings of L and S
FN type is externally regulated, LS type in internal.
Posted on: 2013/2/24 2:56
Re: Need help
Dash lights not working could be a blown fuse, burnt wire, or in my case someone altered the wiring for spotlights
Posted on: 2013/2/25 6:48
