« 1 2 3 (4)
#31 Re: Strong gearbox
D Posted on: 2012/8/23 5:39
#32 Re: Strong gearbox
ChanWilson Posted on: 2013/4/1 5:47
Guys what about the mileage, how much it gives?
#33 Re: Strong gearbox
ddgonzal Posted on: 2013/4/1 5:59
A typical Datsun five speed gives about 20% better fuel economy at 60 mph (100 kph). An almost no difference at 40 mph.
#34 Re: Strong gearbox
shanepickett Posted on: 2013/4/1 6:29
where do you get one of them from , the first 1
#35 Re: Strong gearbox
ddgonzal Posted on: 2013/4/1 6:51
The first photo shown was a Borg-Warner T5. Get one at the wreckers. It doesn't bolt up to A-series engines, so make an adapter.
#36 Re: Strong gearbox
shanepickett Posted on: 2013/4/1 7:36
not the box ,I mean sequential shifter,plus what cars the box comes out of.
#37 Re: Strong gearbox
shanepickett Posted on: 2013/4/1 13:00
did you know that you can get a t50 box rebuilt with any ratios you want. a friend of mine being racing a westfeild with the same box for 4 years an wore it out,motor ca 18 around 190 whp
#38 Re: Strong gearbox
D Posted on: 2013/4/1 13:15
the Nissan 71C sequential shifter is from www.japaneseautocentre.com.au but also avail from Jpn Im sure.
The T5 can be A seriesed using a 5mm adaptor from box to the auto bellhousing, machined input shaft and ford escort type clutch to A series flywheel and ford Hydro release bearing. T5 also has seq shifter but never seen the results of that compared to the 71 series box.
T50 boxes are pricey for the close ratio gearsets while 71c and B boxes are 1400aud from Japan but 71 box needs adapting. However look up the vid of Sykines A12 turbo at PI and hear it upchange on the straight simply awesome. Can only imagine those Z cars devastated if he had an extra 400cc x 1.7 = 2.7 liters closer to big bore L28 & no noise limits.
here is another Ikeya with 71 series box
http://www.youtube.com/watch?v=k2mGfeP5pj4
« 1 2 3 (4)
