Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
32/36 Weber DGV jetting
SunnyDaze
Posted on: 2013/5/4 8:34
I picked up a 32/36 DGV Weber a little while ago for use on my mild a15. It was from a running A series engine. I inspected the jets and found the following:
Main Jets: 150/132 Air Jets: 165/140 Idle Jets: 50/55 Float needle and seat: 2.00 Main Venturi: 26/27 Aux Venturi: 3.5/3.5 Emulsion tubes: f50/f60 I couldnt see how to remove the emulsion tubes to check the numbers on those. Any tips? EDIT: Removed Etubes with a 2.5mm allen key. Anything out of the ordinary here for an a15? Does the jetting look ok as a baseline to start tuning? My plan is to just see how it goes with these jets and take it from there.
#2
Re: 32/36 Weber DGV jetting
LittleFireyOne
Posted on: 2013/5/4 14:09
emulsion tubes are sometimes a little jammed in there, get a needle or something and use friction ot pull it out since you don't have the weber tool. The tubes will be F50, they stay the same for a fair share of cars.
With the mains, is the primary 150 and the secondary 132? that looks too lean on the seconday. My specs on the A14 right now (38\38dges but applicible for capacity): main jets 145\145(might go 155\155) 185 air corrector jets size 4 venturis 55 accelerator pump jet 40\40 idle jets (need bigger) f50/f50 emulsion tubes
#3
Posted on: 2013/5/5 1:42
"mild" A15 -- do you mean lower RPM than factory tuning?
Weber 32/36 Baseline for A-series engine is as follows Main Jets: 140/140 Air Correction Jets: 170/160 Idle Jets: 60/50 Emulsion tubes: F50/F50 Jump jet: 50 But you can you use any tuning for a baseline. You note how it works, then modify it depending. The main/air correction is the last thing to check, first check idle mixture range and acceleration transitions. You can view topic.
