« 1 2 3 (4)
#31 Re: egi intake
patydaty Posted on: 2014/3/31 8:07
how do i fix a glazed block im just interested?
do i need to rebore or is it just polised down?
#32 Re: egi intake
ddgonzal Posted on: 2014/3/31 9:09
You would need to replace the rings and all that entails. A re-ring job rarely needs a rebore unless the cylinders are damaged.
#33 Re: egi intake
clyons8 Posted on: 2014/3/31 9:39
Unfamilia is an expert at sorting out bad rings. He is located in Melbourne.
#34 Re: egi intake
lamb_daiquiri Posted on: 2014/3/31 9:46
The correct way to do it is to measure the bores (usually top and bottom and at 90 degrees, so 4 measurements). If the bores are within spec you can use a de-glazing hone on a hand drill to put the cross hatch pattern back into the bore. (there's more to it than that but that's a good start)
Once the bores are prepared, new rings and often new bearings plus all the gaskets required to put it all back together. If it needs a re-bore then add new pistons as well.
« 1 2 3 (4)
