Re: egi intake
how do i fix a glazed block im just interested?
do i need to rebore or is it just polised down?
Posted on: 2014/3/31 8:07
Re: egi intake
You would need to replace the rings and all that entails. A re-ring job rarely needs a rebore unless the cylinders are damaged.
Posted on: 2014/3/31 9:09
Re: egi intake
Unfamilia is an expert at sorting out bad rings. He is located in Melbourne.
Posted on: 2014/3/31 9:39
Re: egi intake
From Adelaide
The correct way to do it is to measure the bores (usually top and bottom and at 90 degrees, so 4 measurements). If the bores are within spec you can use a de-glazing hone on a hand drill to put the cross hatch pattern back into the bore. (there's more to it than that but that's a good start)
Once the bores are prepared, new rings and often new bearings plus all the gaskets required to put it all back together. If it needs a re-bore then add new pistons as well.
Posted on: 2014/3/31 9:46
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
« 1 2 3 (4)
