56A Modification query
Not too shy to talk
Hi guys
I have given up on 5 speed box.
But I was wondering if any one had extended the ratio of the 4th gear in a 56A box effectively making the 4th an overdrive.
Is the possible. and has anyone done this?
Thanks my friends....
Posted on: 2014/6/18 23:20
Re: 56A Modification query
From Sydney
If your talking about a 56A 4sp box then unfortunately 4th gear is simply the input shaft locked to the output shaft for a direct drive arrangement. Even though the lay shaft will still spin it however doesn't drive the output shaft when in 4th.
Posted on: 2014/6/19 0:43
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Did you find a check sleeve for your 5-speed?
Posted on: 2014/6/19 5:20
If your talking about a 4sp box
* Dan Hall made 5-speeds out of a Datsun 4-speed. See Dan Hall 5-speed
* This has been done with other direct 4-speed boxes. See Changing/custom early gears for a better gearbox
Aichi Machine did it with the 56A by casting a bigger rear case, modifying the main shaft and cluster shaft to accept another gear on the end.
Posted on: 2014/6/19 6:15
Edited by ddgonzal on 2014/6/19 7:24:58
