Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Toyota T50 5 Speed
Posted on: 2014/6/23 12:15
Yep whole l conversion and 5 speed was cheaper sort of
#12
Skremn
Posted on: 2014/6/23 23:39
its a bit more expensive than your price list. ddgonzal. I got a list from Dellows a few months back. Prices are now
Bell Housing & Pivot Ball $700 Spigot Bush $40 Thrust Race Bearing $85 Return Spring Retainer Ring $30 Clutch Plate $175 Transmission Rubber Mount $110 Transmission Gasket $30 Speedo Cable $115 Tail Shaft Yoke $165 Weld Yoke $85 Universal Joint $85 Toyota T-Series 5-Speed (reconditioned) $1100 TOTAL $2720 All prices quoted are inclusive of GST and subject to change.
#13
Posted on: 2014/6/24 3:37
Hmm... a brand new FS5W60B 5-speed is only $1700. Even with shipping it should be less than the Dellow price.
#14
Skremn
Posted on: 2014/6/24 4:17
True, but once you have the kit, if you break a box, it's an cheaper swap, than to have to buy another 1700 gearbox
#15
benny
Posted on: 2014/6/24 4:45
IMO, most of the kit items listed are priced over and above what you reasonably would pay. The cast bell-housing would be the only thing you actually need from Dellow, the rest you can sort out yourself from other suppliers /ebay for substantially less.
#16
D
Posted on: 2014/6/24 5:14
It would be cheaper and better in the long run to cut and shut a stumpy 71 series box with an auto bellhousing from an A series. A good welding fabrication place or person can do it and most of the work is setting it up with a jig and welding. If someone was able to make a jig and share it many of us would be more than happy to fork out 800-1000 for a 5 speed setup that is easier to source parts for not to mention a whole box. There is one member with such a jig and would be great if he could rent it out.
