« 1 (2)
Re: Toyota T50 5 Speed
Yep whole l conversion and 5 speed was cheaper sort of
Posted on: 2014/6/23 12:15
From Sydney NSW
its a bit more expensive than your price list. ddgonzal. I got a list from Dellows a few months back. Prices are now
Bell Housing & Pivot Ball $700
Spigot Bush $40
Thrust Race Bearing $85
Return Spring Retainer Ring $30
Clutch Plate $175
Transmission Rubber Mount $110
Transmission Gasket $30
Speedo Cable $115
Tail Shaft Yoke $165
Weld Yoke $85
Universal Joint $85
Toyota T-Series 5-Speed (reconditioned) $1100
TOTAL $2720
All prices quoted are inclusive of GST and subject to change.
Posted on: 2014/6/23 23:39
There maybe faster ways to go...
But I'm never in a rush
Hmm... a brand new FS5W60B 5-speed is only $1700. Even with shipping it should be less than the Dellow price.
Posted on: 2014/6/24 3:37
From Sydney NSW
True, but once you have the kit, if you break a box, it's an cheaper swap, than to have to buy another 1700 gearbox
Posted on: 2014/6/24 4:17
From Sydney
IMO, most of the kit items listed are priced over and above what you reasonably would pay. The cast bell-housing would be the only thing you actually need from Dellow, the rest you can sort out yourself from other suppliers /ebay for substantially less.
Posted on: 2014/6/24 4:45
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
It would be cheaper and better in the long run to cut and shut a stumpy 71 series box with an auto bellhousing from an A series. A good welding fabrication place or person can do it and most of the work is setting it up with a jig and welding. If someone was able to make a jig and share it many of us would be more than happy to fork out 800-1000 for a 5 speed setup that is easier to source parts for not to mention a whole box. There is one member with such a jig and would be great if he could rent it out.
Posted on: 2014/6/24 5:14
« 1 (2)
