eliminating mechanical fuel pump.
hi guys..
what will be the gain by eliminating mechanical fuel pump from a15 engine? power? smoother? as the cam shaft no need to push the spring on the fuel pump?
any one has test it? by replacing it with electrical fuel pump?
(standard a15 carb)
Posted on: 2014/9/14 17:31
Re: eliminating mechanical fuel pump.
From Las Vegas USA
For a stock motor there will really be no performance advantage. There are some advantages; when mechanical pumps fail they tend to leak fuel, if the car is going to be parked for a bit you can pump the tank out, on my race car I have a toggle switch for the pump so before I park the car I turn the pump off and run the float bowls near dry........as my car ends up parked for up to two months over the summer (it's 112 degrees out) this keeps the carbs from getting gunked up. Also should you ever run your car out of gas it makes it easier to fire up.................ask me how I know.
Tom
Posted on: 2014/9/14 18:03
No performance advantage? Hmmmmm.
Thanks for reply....
Posted on: 2014/9/15 2:37
