Re: Just finish fitting bike carbs - awesome
From Las Vegas USA
I suspect that when you put the car on a Dyno that you will go up to around 130-132 mains. I'm running a similar cam but have 39mm Keihins with 155 mains which in Mikuni is around the 130-132, I have yet to run mine on a Dyno either but was able to pick up a few more RPMs by going from 152 to 155s. I did Dyno the A12 and when we got close the last change was going up one jet size, which was good for 4 HP, something I may not have done because the car pulled really well even though it was a touch lean.
As for the throttle cable I had a custom one made, this is fairly common for motorcycles, my buddy had enough of the parts in his shop to make one up.
I have very little experience with DCOEs but the sports racer guys who used A-Series engines picked up 10 HP by simply switching to FCR carbs.
Tom
Posted on: 2014/11/18 4:52
Subject Poster Date
     Just finish fitting bike carbs - awesome zigmondo 2014/11/13 9:47
       Re: Just finish fitting bike carbs - awesome Anonymous 2014/11/13 11:51
       Re: Just finish fitting bike carbs - awesome anths 2014/11/13 20:29
         Re: Just finish fitting bike carbs - awesome clyons8 2014/11/14 1:18
       Re: Just finish fitting bike carbs - awesome bakat 2014/11/14 4:19
         Re: Just finish fitting bike carbs - awesome zigmondo 2014/11/14 10:36
           Re: Just finish fitting bike carbs - awesome Anonymous 2014/11/14 11:42
             Re: Just finish fitting bike carbs - awesome andrew1200 2014/11/15 9:16
               Re: Just finish fitting bike carbs - awesome zigmondo 2014/11/15 10:03
                 Re: Just finish fitting bike carbs - awesome clyons8 2014/11/15 10:31
                   Re: Just finish fitting bike carbs - awesome Anonymous 2014/11/15 11:30
       Re: Just finish fitting bike carbs - awesome D 2014/11/18 3:01
       Re: Just finish fitting bike carbs - awesome Rallytwit 2014/11/18 4:52
         Re: Just finish fitting bike carbs - awesome clyons8 2014/11/18 8:27
       Re: Just finish fitting bike carbs - awesome 72datto 2014/11/19 1:23
       Re: Just finish fitting bike carbs - awesome coxsteve 2014/11/28 22:09
       Re: Just finish fitting bike carbs - awesome Rallytwit 2014/11/29 5:29
         Re: Just finish fitting bike carbs - awesome D 2014/11/29 10:46
       Re: Just finish fitting bike carbs - awesome coxsteve 2015/1/2 11:53
       Re: Just finish fitting bike carbs - awesome Rallytwit 2015/1/3 2:25
         Re: Just finish fitting bike carbs - awesome D 2015/1/3 3:34
           Re: Just finish fitting bike carbs - awesome Anonymous 2015/1/3 7:51
             Re: Just finish fitting bike carbs - awesome D 2015/1/4 0:46
               Re: Just finish fitting bike carbs - awesome ddgonzal 2015/1/4 3:17
                 Re: Just finish fitting bike carbs - awesome D 2015/1/4 11:11
       Re: Just finish fitting bike carbs - awesome Rallytwit 2015/1/5 4:18
         Re: Just finish fitting bike carbs - awesome coxsteve 2015/1/13 9:33
       Re: Just finish fitting bike carbs - awesome rockitdoc 2015/3/9 22:48
       Re: Just finish fitting bike carbs - awesome Rallytwit 2015/3/12 2:34
