(1) 2 3 4 5 »
#1 Flaring my ute guards
zigmondo Posted on: 2015/1/9 10:09
Just finished the A15 and 60 ser 5 spd swap so now I want to put 13 x 7 minilites on my ute but need to flare the rear guards 35mm and the fronts 25 mm to get them under.
So here goes - before and during photos and some more to come as I progress
jpg  P1010042.JPG (164.69 KB)
16236_54afa82d83e00.jpg 640X480 px
jpg  P1010046.JPG (149.87 KB)
16236_54afa8443d54e.jpg 640X480 px
jpg  P1010049.JPG (155.94 KB)
16236_54afa8776f9a7.jpg 640X480 px
jpg  P1010055.JPG (161.53 KB)
16236_54afa88e22b25.jpg 640X480 px
#2 Re: Flaring my ute guards
ddgonzal Posted on: 2015/1/9 11:41
You got guts. It will look good when you are done.
#3 Re: Flaring my ute guards
Brevlin Posted on: 2015/1/9 13:45
Absoloutely loving this!
#4 Re: Flaring my ute guards
datsa73 Posted on: 2015/1/9 19:07
Dave's right. I just cant think of flaring my car. I would rather go in than out. It will look good when its done.
#5 Re: Flaring my ute guards
nickmitty Posted on: 2015/1/10 0:32
Other alternative is to have hand beaten them wider with out cutting like Lowmion did.
#6 Re: Flaring my ute guards
datsunbeginner Posted on: 2015/1/10 0:39
What's your plan of attack? I see that you have cut slots in the guards. What's next? Are you going to weld the pieces together?
#7 Re: Flaring my ute guards
Skremn Posted on: 2015/1/10 4:17
Im curious how this turns out..
#8 Re: Flaring my ute guards
zigmondo Posted on: 2015/1/10 7:02
Ok - to start with, if you look carfully I had to remake a piece to mimic the 15mm flat section at the edge of the guard ( it was too rusted to weld to ). I've cut away the the inner guard about 20mm up from where it origonally joined the outer, then cut it in a similar way to then bend it up to meet the outer guard about where the flare starts. This will give me greater wheel travel clearance and when its welded back and will brace the panel once again.
The outer edge of the newly flared guard will have a 4mm round bar welded to it to give a nice edge and strength/rigidity.
Will be doing both rear sides at the same time to keep it as uniform as possible, then move onto the easier (?) fronts in a similar manner.
The plan is for the finished guard to have a 'similar' look to the standard one with the 15mm flat vertical section all the way round. ( well thats the plan anyway!)
It may not be the 'right' way and there will always be 'another' way, but it's the way I want to do it - so we'll see in the end
dp
PS: once they're finish it will be lowered as much as it will allow without scraping
#9 Re: Flaring my ute guards
zigmondo Posted on: 2015/1/14 5:41
Progress on the other side
jpg  P1010058.JPG (159.08 KB)
16236_54b60163d5d4d.jpg 640X480 px
jpg  P1010059.JPG (154.50 KB)
16236_54b60174b15e2.jpg 640X480 px
#10 Re: Flaring my ute guards
cadet1200 Posted on: 2015/1/14 9:12
Looks like it's all coming together like you planned. You gonna have them all finished off in time to display them at your BBQ day?
(1) 2 3 4 5 »
