« 1 2 (3) 4 5 6 ... 16 »
Re: Elrich11's CA18DET 1200 Ute
From Geelong, Victoria
___1200ute wrote:
I have an s13 setup in my ute. I'm using S12 LCAs but had to section about 25mm out of each one to get the track back within the requirements. I section the area between the ball joint and the castor rod mount. The engineer I'm using for the design code (Ls3) is happy with this.
I was thinking about cutting the LCA from the treaded body section as it would be a simple mod, but the ball joint angle may be a problem. Your method is better to keep the ball joint angle reasonable. I also have a few sets of standard S13 LCAs which I can fool around with if I can engineer it.
Posted on: 2015/1/17 10:09
Been a while since my last post, have been progressing with a few things, underneath painted, diff built with LSD and 4.11 gears, all new bushes and shocks. S13 front end pretty much sorted but will be on a seperate post with some detail of how I went about it. Waiting on inner tie rod ends which I should have Monday and it'll be back on the floor!
Car will be going out to a fabrication workshop next week to finally get the trans tunnel finished. will get the motor onto the engine stand whilst the car is out of the garage and get a few things sorted on that. Slowly but surely it's moving along!
jpg  image.jpg (90.46 KB)
17122_54e9ab1cdfab6.jpg 640X480 px
jpg  image.jpg (84.13 KB)
17122_54e9ab3257b10.jpg 640X480 px
jpg  image.jpg (67.18 KB)
17122_54e9ab5029aee.jpg 640X480 px
Posted on: 2015/2/22 10:15
First update in a while, progress is slow but progress none the less.
Engine bay painted so that I could fit suspension and steering, decided black because it was easy and still looks ok.
jpg  image.jpg (79.60 KB)
17122_5531a074e2fcc.jpg 640X480 px
Posted on: 2015/4/18 1:08
13 front in and steering all done! Got some new coilovers with base height and dampening adjustment.
If anyone is doing the S13 conversion, it says in the tech wiki to use s13 outer tie rod ends and machine the tie rod to suit, an easier way is to use an S14 outer tie rod end as it is the same diameter and thread pitch as the 1200 so no machining required :).
I had to make up some bushes to accept the smaller diameter (10mm) 1200 cross member bolts on the s13 adjustable arms and also the s13 cross member mount is narrower, that was the only fabrication required for the entire conversion.
jpg  image.jpg (82.46 KB)
17122_5531a0c36a66b.jpg 640X480 px
jpg  image.jpg (108.75 KB)
17122_5531a0df1c226.jpg 640X480 px
jpg  image.jpg (84.60 KB)
17122_5531a0f28b08a.jpg 640X480 px
jpg  image.jpg (70.27 KB)
17122_5531a101abff9.jpg 640X480 px
Posted on: 2015/4/18 1:11
Wheels on and car is coming off the stands today to finally go out to the fabricators for welding of the trans tunnel and also some radiator mounts and support. Feels nice to actually reach the next stage.
jpg  image.jpg (93.47 KB)
17122_5531a197e64d4.jpg 640X480 px
jpg  image.jpg (71.33 KB)
17122_5531a1b390964.jpg 640X480 px
Posted on: 2015/4/18 1:14
From Mordialloc Victoria 3195
Nice progress - looking good - photoshop out the pavers , they scare me.
Posted on: 2015/4/19 23:41
keep it simple
My Photoshop skills are coming along, can't even tell that they were there....
jpg  20.04.15 030 Mod.jpg (189.54 KB)
17122_5534435d73cee.jpg 808X606 px
Posted on: 2015/4/20 1:09
So you went with the red S13 adjustable LCA's that were pictured earlier in your thread. Did you end up modifying (shortening) them ? How are you going for track width as wheels still appear to be hanging out a bit.
It looks like you end up with heaps of room inboard (between strut and rim) compared with the 120y strut setup.
Very interested to follow your build and hear what the ride quality is like with this setup.
Keep up the good work.
Posted on: 2015/4/20 6:58
You 'Da' Photoshop man - I feel better now
Hey A'- stop reading his build thread and get out into the garage
Posted on: 2015/4/20 8:23
keep it simple
From New zealand
Good work man ! I'm in the process of painting my r31 diff and getting it rebuilt in a couple of wks ! Question ..... How does the ute sit with the diff ? What sought of clearance do you have between the guard and wheels ?
Posted on: 2015/4/20 10:23
Be aware take care avoid life in a wheelchair
Dattos - 1200 ute 4agze, 1600 L18 twin Su, 1600 ca18det
Current - building a ca18det 1200 ute and drag 1200 ute undecided on the donk !
