#1 Lookn at replacn my 1200 seats and just wondering...
Regulator Posted on: 2004/6/17 1:41
If Datsun 1600 rails will fit? I have found some Rx7 buckets with 1600 datsun rails. Will these fit my 120y?
#2 Re: Lookn at replacn my 1200 seats and just wondering...
pro-240c Posted on: 2004/6/17 1:57
not sure about the 1600 rails, but i know 200B seats fit the stock 1200 rails with a bit of work.
the outside bolts are the same spacing. but the inside bolts need to be welded to the rail. you could always make up a 6 or 8mm thick spacer plate and bolt to that instead though, i was just lazy...
#3 Re: Lookn at replacn my 1200 seats and just wondering...
Regulator Posted on: 2004/6/17 2:07
Orsome. What are the 200b seats like? Are they more bucket than the 1200? Cuz man, I pretty much slide off mine.
#4 Re: Lookn at replacn my 1200 seats and just wondering...
dattodude Posted on: 2004/6/17 4:32
200B Seats are too wide, and are designed for fat old men. They'd impede on the handbrake access, which is bad if you like doing handbrake turns.
Mazda RX7 Series 2 seats have the same rail and mounting bolt spacing. Please confirm this before shelling out cash for them.
Cheers,
Chris
#5 Re: Lookn at replacn my 1200 seats and just wondering...
pro-240c Posted on: 2004/6/17 6:12
no, they're not too wide at all. i had them in my sedan and they fit fine with the adaption i talk of.
and anything is better than the std fixed back vinyl 'buckets' - and i mean ANYTHING.
#6 Re: Lookn at replacn my 1200 seats and just wondering...
Regulator Posted on: 2004/6/17 7:32
Must say though...I love my handbrake.
#7 Re: Lookn at replacn my 1200 seats and just wondering...
dattodevil Posted on: 2004/6/17 7:39
From memory, I think the seat rails are 400mm apart, I have fitted S15 Silvia Recaro seats to mine and they were the same width apart as my ute. Just added 3/4 box section which adapted the datsun rails to fit and also raised then up a little. They sit a little lower and a little further back, which in the Ute is always a good thing. They are still able to be adjusted forward and back.
#8 Re: Lookn at replacn my 1200 seats and just wondering...
Ash Posted on: 2004/6/17 7:40
Do 120Y seats bolt in? I have a recaro for myself but I need something better for my passanger.
Sorry for the hijack
#9 Re: Lookn at replacn my 1200 seats and just wondering...
_steve_ Posted on: 2004/6/17 11:16
mazda 121 seats ar good i have a pic http://datsun1200.com/modules/myalbum/photo.php?lid=3931 the pic is not 2 good
#10 Re: Lookn at replacn my 1200 seats and just wondering...
Regulator Posted on: 2004/6/18 0:52
YEah, I'll have to hunt around.
