Wanted: CA18DET Loom and ECU
Quite a regular
From Melbourne, VIC
Chasing a stock loom and ECU to suit CA18DET with manual transmission
The current loom and ECU i have appear to be for non turbo and is missing a few connectors.
It doesn't have to be in great condition,, i just really need something to get the engine fired up, as the plan is to swap over to a Haltech so will probably re-loom the entire car at some point.
Let me know what you have.
Cheers,
Mat.
Posted on: 2018/6/30 7:46
Re: Wanted: CA18DET Loom and ECU
I've probably got an ECU. Do you know what number should be on it?
Posted on: 2018/6/30 13:13
Quite a regular
From Melbourne, VIC
Not sure which ECU I actually need, but the 2 that I have are "65" ECUs.
I think the part number is 35F11??
The loom that I have is missing a few injector plugs, and the ones that are on it don't fit the injectors anyway as the "alignment pins" are not the same (offset vs central).
Posted on: 2018/6/30 22:56
We spent 16 years seeing other cars and other people, but now we are back together.
We are both a bit older and a little wiser, we have a few scars and plenty of stories to tell.
Time to rebuild the old relationship and enjoy many more years together...
Quite a regular
From Melbourne, VIC
From what I can tell the 35F11 ECUs are for a Non Turbo Auto.
I am pretty sure I need a 36F00 or 36F05.
Posted on: 2018/6/30 23:16
Ok I just dug up the two I have and both are "98" 36F00.
PM me your phone number and I can give you a call.
Posted on: 2018/7/1 2:33
