Z18 turbo injectors
Quite a regular
From Sydney,Campbelltown.NSW
hey, dose anyone out there know what injectors would be decent for a Z18, my current injectors are cloged so i thought i might as well buy bigger and better one`s is this a good idea......if so what kind off injectors...... anyhelp would be great.....thanks.....
DATSUN 200B Z18 TURBO
Posted on: 2004/6/29 13:04
Re: Z18 turbo injectors
Bigger injectors would not be a good idea unless the engine is flowing a lot more air than stock. You want to keep the injectors within their designed operating cycles. But if you've doubled the boost, then bigger injectors would be good. Perhaps the ones from the 280Z or 300ZX would fit?
Posted on: 2004/6/29 16:47
Quite a regular
oh ok yeah i was thinking of putting the boost up 15 psi after some head work, intercooler and a bigger fuel pump. dose anyone know how hard it is to install a vL turbo fuel pump in my z18 thanks 4 the help
Posted on: 2004/6/30 10:14
Quite a regular
You could try fj20det ones, aparrently they are a straight fit.
Posted on: 2004/6/30 14:29
120y 2dr sedan, Z18t
