#1 Performance oil filter
UTE18L Posted on: 2004/10/12 7:25
can anyone recomend or know of a performance oil filter for the CA engines, i currently use the RYCO Z145A, no probs but would like to try something else.
#2 Re: Performance oil filter
ddgonzal Posted on: 2004/10/12 7:28
How much extra performance is a performance filter good for?
#3 Re: Performance oil filter
NIS15L Posted on: 2004/10/12 7:38
Im trying a magna filter Contains a magnet inside to stop and metal from entering the motor.
#4 Re: Performance oil filter
UTE18L Posted on: 2004/10/12 7:40
ok then, a filter that would be used on a race engine, so that it has higer flow rates (?) and most importantly has higher fitlering capabilities. As my oil is as black as midnight after 5,000 Km
Dont think a quality filter it will have any performance advantages, but will filter better and flow more therefore cleaner oil, and a better running engine, ideal for 'performance', dont you think DD???
#5 Re: Performance oil filter
UTE18L Posted on: 2004/10/12 7:41
do you have a part number for this magna filter???
Will it need any mods???
#6 Re: Performance oil filter
Abyss Posted on: 2004/10/12 7:46
What kind of oil are you running? It may have something to do with it going black quicker.
#7 Re: Performance oil filter
UTE18L Posted on: 2004/10/12 7:57
mobil fully synthetic.
#8 Re: Performance oil filter
NIS15L Posted on: 2004/10/12 7:58
Will check the part number when i get home today.
#9 Re: Performance oil filter
Abyss Posted on: 2004/10/12 8:23
Well there goes that theory
So I am assuming it is Mobil 1 then? I have used Mobil 1 in my other car and it stayed pretty clean for 10,000km's.
Sorry but I don't have any other suggestions
#10 Re: Performance oil filter
Freak Posted on: 2004/10/12 8:30
I know its fuel injected but is it running rich. This could cause black oil. However rare on electonic fuel injected motors.
Also probably not the case as I assume the engine is new but the rings could be worn allowing blow by down into the crank case making the oil black.
Also remember if you flog it heaps you will have to change the oil more reguarly.
