Re: Bore a12 how far can you go
What clearancing would be needed to fit the a15 crank in? Just the crank or block as well?
I suppose thats whats needed to get 1600cc from an a12 right?
If so it means this particular a12 will need 79mm bores which is amazing.
Posted on: 2005/4/4 16:32
Subject Poster Date
     Bore a12 how far can you go greg12 2005/4/3 12:27
       Re: Bore a12 how far can you go 2332owner 2005/4/3 13:47
         Re: Bore a12 how far can you go tsillay 2005/4/3 23:25
       Re: Bore a12 how far can you go datral_10 2005/4/4 2:06
       Re: Bore a12 how far can you go vixen 2005/4/4 4:08
       Re: Bore a12 how far can you go D 2005/4/4 16:32
         Re: Bore a12 how far can you go D 2005/4/5 9:49
           Re: Bore a12 how far can you go tsillay 2005/4/6 1:21
             Re: Bore a12 how far can you go D 2005/4/6 2:22
               Re: Bore a12 how far can you go L18_B110 2005/4/6 6:53
                 Re: Bore a12 how far can you go Dodgeman 2005/4/6 7:21
                   Re: Bore a12 how far can you go L18_B110 2005/4/6 9:00
                     Re: Bore a12 how far can you go Dodgeman 2005/4/6 14:35
                       Re: Bore a12 how far can you go L18_B110 2005/4/7 0:59
                         Re: Bore a12 how far can you go pro240c 2005/4/7 4:51
                         Re: Bore a12 how far can you go chowdozer 2005/4/7 6:40
                           Re: Bore a12 how far can you go L18_B110 2005/4/7 7:02
                             Re: Bore a12 how far can you go D 2005/4/7 8:55
                               Re: Bore a12 how far can you go pro240c 2005/4/7 9:55
                                 Re: Bore a12 how far can you go A14force 2005/4/7 10:47
                                   Re: Bore a12 how far can you go Dodgeman 2005/4/7 12:37
                                     Re: Bore a12 how far can you go 1200GXman 2005/4/7 13:14
                             Re: Bore a12 how far can you go chowdozer 2005/4/7 15:26
             Re: Bore a12 how far can you go Dodgeman 2005/4/6 6:49
