MY 180B struts have POS- camber, how do i fix??
From VIC, bendigo.
ive just done the 180B strut, verada disks and commodore calliper brake up grade, obviously the strut length is way to long so i will be lowering with different springs, but im pretty sure, the camber is all out of wack, i read somware to change the ball joints??
is this correct?
Posted on: 2005/7/31 12:12
1200 Sedan.Turbo A14 drawthrough 15psi Meth inj 104rwkw
1200 coupe club car. turbo L20 drawtrough
Re: MY 180B struts have POS- camber, how do i fix??
From Melbourne AUS
if you have the 180b springs in there they are probably causing your +camber..
get the ride height back to normal or lower and you will see an improvement
Posted on: 2005/7/31 12:51
1973 B110 A12
From Sydney, Australia
Thats what I'm running.
180B struts + Verada + Commodore Calipers + Stanza lower arms and balljoints. Using 1200 strut tops (bearing & carrier)
I've got a good deal of negative (good) camber 3 degrees or so.
I've cut down my 180B strut tubes to fit 240Z inserts.
I then repositioned the cup so that it captures a 2 inch lower "Pedders red" 1200 spring
Hope this helps.
Posted on: 2005/7/31 13:12
From VIC, bendigo.
righto!!
i'll get the ride height set first and see what happens, cheers guys!!
Posted on: 2005/8/1 0:00
From VIC, bendigo.
Dattodude: how much lower are the 240Z inserts?? sounds like a better option.
Posted on: 2005/8/3 5:49
From Brisbane Australia
i used skyline inserts they are 362 u have to cut the tubes done though
Posted on: 2005/8/3 10:18
From memory about 2 inches.
I might have it referenced on my website.
It was done almost 5 years ago...damn 4 year projects..
Watch this space...
Posted on: 2005/8/3 11:37
