Re: L20B into 310 Sunny? S13 struts into 310?
From Christchurch NZ
I just got mine on the road tonight. It goes really good. You will have to recess the Xmember like karl said. If you start with gear from a bluey, it will be easier. If you score a bluey as a donor car, you might as well use the bluey struts as well. All you have to do is put the sunny strut tops on them, and get a ring made to adapt the bluebird strut to the sunny steering arm.
Like karl said, you'll also need to change to hydraulic clutch, but when you gat all the gear it becomes pretty self explanitory.
Posted on: 2005/8/30 9:57
Forced Induction!
Subject Poster Date
     L20B into 310 Sunny? S13 struts into 310? floody 2005/8/30 3:19
       Re: L20B into 310 Sunny? S13 struts into 310? datsun120ycoupe 2005/8/30 3:40
         Re: L20B into 310 Sunny? S13 struts into 310? A14force 2005/8/30 9:57
           Re: L20B into 310 Sunny? S13 struts into 310? datsun120ycoupe 2005/8/31 5:30
             Re: L20B into 310 Sunny? S13 struts into 310? A14force 2005/8/31 9:18
               Re: L20B into 310 Sunny? S13 struts into 310? Lurch 2005/8/31 9:57
                 Re: L20B into 310 Sunny? S13 struts into 310? datsun120ycoupe 2005/8/31 16:44
                   Re: L20B into 310 Sunny? S13 struts into 310? Lurch 2005/9/1 10:33
                 Re: L20B into 310 Sunny? S13 struts into 310? floody 2005/9/1 14:52
