Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Carburetor
Tham
Posted on: 2005/12/5 9:32
I would like to apologize to this forum's
administrators and users if my post seems out of place here. I'm from Kuala Lumpur, Malaysia. I'm a Toyota Corolla "DX" KE70 owner, with a 1,290 cc 4K engine, 1981 model. I have changed the carburetor three times - a used one at first, then two brand new ones. The current new one is still giving endless rough idle problems, and I have read this is common with these problematic Aisan carburetors. I'm considering changing over to the Datsun 120Y B210's A12 engine's Hitachi carburetor, or perhaps that of the B11 Sunny's , and I wonder if it can be installed in my engine ? Thank you.
#2
Re: Carburetor
WhiteSedan
Posted on: 2005/12/5 9:52
An A-series carb will not fit, wrong bolt spacing. L-series carb will fit no worries, you'll have to rejet and work out linkage and emissions etc.
#3
Re: Carburetor
Tham
Posted on: 2005/12/6 3:18
Thanks very much, I will check this out.
I believe the L-series were older engines were used on the Datsun 1600 SSS, etc ?
#5
Re: Carburetor
dattodude
Posted on: 2005/12/6 8:02
Hi Tham, the 1600 SSS uses twin SU type carburettors, not what you are looking for.
Are you sure that your problem is the carburettor? It's not ignition related or a blown head gasket or something else? Good Luck with the fix!
#6
Re: Carburetor
phunkdoktaspok
Posted on: 2005/12/6 8:46
I tend to agree. Tried 3 other carbies and still the same problem. Time to look elsewhere.
Maybe manifold leak, maybe rocker clearance, maybe burnt valve. Lots of things besides carbie.
#7
Re: Carburetor
Tham
Posted on: 2005/12/6 15:31
Thanks, Dattodude, Phunkdoktaspok and Maztec.
The basic problem is basically, right after starting up, the idle speed seems OK. If I drive off the car at speed, and I don't get held up much by traffic, it will run fairly well too. However, if I leave it at idle right after starting, or if I get held up by traffic after some running, and the temperature gauge starts climbing towards to the 2/3 or middle position, the erratic idle starts to come in, with the engine sputtering a bit, close to dying. It did die off once, but I managed to start it back, though with the engine sputtering and struggling to hold idle. I only managed to keep it from dying again by pulling out the manual choke as a last resort. I can't really figure out what's wrong, but think it's the idle circuit in the carburetor. Yes, I did have the mechanic tighten the manifold nuts, suspecting a manifold leak too. The head gasket has just been changed, valves decarbonized, valve seals replaced and rocker clearances adjusted. The mechanic is really scratching his head too. (The mechanics over here aren't particularly skillful, though.) The ignition system was the first to be suspected. I'm using a contact points-triggered electronic ignition system made from a kit by Dick Smith Electronics, Australia, originally designed by Silicon Chip magazine. I tried switching back to the standard points ignition, but it was the same. The contact points and condenser have just been changed too. Initially the vacuum advance pump at the distributor was causing this rough idle problem too. What happened was the original pump had given way, and the only replacements available here were generic "Century" brands made in Japan (or so the label said, but I suspect more likely from Taiwan). Well, this pump has a plastic adjuster at the rear for fine timing adjustments. The stock Nippondenso one was very well made and heat durable, but this replacement's adjuster was not, and virtually disintegrated from the heat after a few months. Once this happened, the timing went haywire, since this adjuster was at the end of a tensioner spring indenting against the pump's arm connected to the distributor's plate. I had to buy another pump, same thing happened after a few months again, before my brother-in-law finally fashioned a copper adjuster and screwed it in. The ignition timing at idle appears to be holding well since then. The spark plugs, plug leads, ignition coil have all been replaced. Fuel pump and filter have been changed too. After the second carburetor change, the problem appeared to go away after I replaced the mechanical fuel pump, suspecting it didn't have enough pumping capacity anymore. It's just over a year since, but I'm wondering whether this pump is starting to give way too ? There are lots of Taiwanese parts being passed off as Japanese ones in Malaysia. There is a quite a bit of discussion in the forum in the Toyota Starlet website (www.kp61.net), that the stock Aisan carburetor is not very well designed and prone to all kind of rough idle problems, virtually impossible to correct with the idle mixture and idle speed screws. The Starlet in the US has the same 1,290 cc, 4K engine as my Corolla, and basically the same Aisan carburetor. One owner complained his idle speed varied anywhere from 700 to 1,000 rpm ! I had also read in the forum of a Suzuki jeep website (can't really remember the URL), which also comes with Aisan carburetors, that this is the case too. The owner who made the post mentioned that the source of this rough idle problem appeared to be a "power piston" in the idle circuit. The function of this piston is to enrichen the mixture during low vacuum conditions, such as idle. If there are even micro-abrasions in its chamber, possibly from wear and tear, the piston will behave erratically, the mixture will become way to rich, and the engine will likely sputter and die. This owner was quite innovative - he managed to rebore the chamber and replate the piston or something, and the idle was fine after that. This is one jinxed car, but I'll try checking out for things like manifold leaks, igntion and fuel pump problems again.
#8
Re: Carburetor
vex66
Posted on: 2005/12/8 14:05
I'm no expert but it might be vapour lock. The fuel line or carby gets hot & the fuel vapourises. Or it could be water or dirt in the fuel. It definitely sounds fuel related.
#9
Re: Carburetor
Tham
Posted on: 2005/12/8 15:27
Thanks, Vex. Yes, it may well be vapour lock.
How does one really cure vapour lock ? I've read about switching over to electric fuel pumps, but the mechanics over here don't really know how to handle this kind of modification.
#10
Re: Carburetor
pager
Posted on: 2005/12/9 9:19
plenty of carbie cars had electric fuel pumps. 1 comes to mind honda accord 1980 up to 1988? it should be reasonablely easy to convert it to the corolla you just need to mount it an connect it up
