Suck-through turbo with intercooler and no carbon seals?
From Canberra
OK so I'm a bit over the inefficiency of the sc12 supercharger, and want to go turbo. I have got a T25 and can get a turbo manifold for ~$200 from the US, but inlet manifolds are a bit more tricky. It's currently suck through, and I think it would be pretty easy to put the throttle body in front of the turbo and use the standard manifold.
Intercooling wont be a problem because it wont have petrol through it, but what I want to know is do turbo's leak oil because of the petrol, or the vacuum when the throttle is closed? ie. will I need carbon seals even though theres no petrol going through the turbo?
You can see there's plenty of room on the exhaust side, and if I use a supra/soarer intercooler with the outlets on the same side piping shouldnt be too bad.
Posted on: 2007/10/7 9:19
Subject Poster Date
     Suck-through turbo with intercooler and no carbon seals? Tyrie 2007/10/7 9:19
       Re: Suck-through turbo with intercooler and no carbon seals? 1200rallycar 2007/10/7 9:24
         Re: Suck-through turbo with intercooler and no carbon seals? Tyrie 2007/10/7 9:54
           Re: Suck-through turbo with intercooler and no carbon seals? Anonymous 2007/10/7 22:19
             Re: Suck-through turbo with intercooler and no carbon seals? Tyrie 2007/10/8 1:55
               Re: Suck-through turbo with intercooler and no carbon seals? Booster 2007/10/8 4:06
                 Re: Suck-through turbo with intercooler and no carbon seals? Tyrie 2007/10/8 6:09
                   Re: Suck-through turbo with intercooler and no carbon seals? A14force 2007/10/8 8:03
                     Re: Suck-through turbo with intercooler and no carbon seals? Tyrie 2007/10/8 8:15
                       Re: Suck-through turbo with intercooler and no carbon seals? kululadotgroen 2007/10/8 13:15
