Diff Q&A
From sydney,Australia
i am also after abit of info on diffs. i am currently in the process of looking for a new diff for my 1979 1200 ute and i have enquired on a borg warner diff that another member has on another forum. now just wondering if it will bolt straight into my ute or will i have to do some moddifications to the tailshaft or the diff mounts at all?
Posted on: 2006/4/27 14:02
Re: Diff Q&A
From SE Melbourne
I would have thought the H165 in the ute would be a pretty good diff, strong, 4.1 ratios...
Are you going for an LSD?
What sort of BW diff is it?
Posted on: 2006/4/27 14:08
Mildman, Datsunless
Re: Diff Q&A
From hastings vic
also looking for diff?
Posted on: 2006/4/27 14:48
1200 sed, big brakes, ca18det, FUN
Re: Diff Q&A
Unless the Borg Warner rear axle assembly is a narrowed one from a Skyline, or other suitable car, it will not be an improvement over the H165 version that comes standard under the 1200 utes.
The advantage of the H165 differential is that it comes in a variety of ratio's, has LDS available, & you can switch these into your ute's rear axle housing in your driveway, in an afternoon.
You can't do that with a Borg Warner unit.
Posted on: 2006/4/27 15:47
Love your Datsun.
Treat it well.
Re: Diff Q&A
dat51k, if you are thinking about the BW rear assembly from a Aussie B210, probably it will work if you use the matching B210 tailshaft -- and with slight bracket modifications to spring mounts, handbrake cable, etc (the same modifications you'd have to do to fit a 1200 sedan diff to the newer ute).
But like they say, the '79 ute should already have the strong H165 diff.
Posted on: 2006/4/28 4:36
Re: Diff Q&A
yeah mine is the H165 but it is starting to make some noises that i have been noticing abit more now and not sure how long it will last.
Posted on: 2006/4/28 9:34
Re: Diff Q&A
Is that so? I must have just been lucky for say oh about 5 times in drive ways, footpaths and gutters.
If you can own tools to work on a car - then you can damn well own a spreader plate to remove a borg warner centre.
Commonsense always prevails.
Posted on: 2006/4/29 5:26
