5 Speed Close Ratio transmission parts for sale
From St. Louis, MO USA
ALL of these parts are NLA. All for the 5-speed racing gearboxes (factory option on some Sunnys). NOT for the STOCK 5-speeds.
Main Drive Gear (also called Input Gear) #32200-H7200 (19 teeth). Counter Gear #32213-H7201. 3rd Gear #32269-H7200. 4th Gear 32270-H7201.
For the close ratio (know as the ultra close ratio in the states). 3rd Gear 32262-H7220. 4th Gear 32272-H7220.
New coupling rings for either ratio, # 32606-H7200. This is the ring that the shift fork rides in and which slides over the syncro ring.
Used parts available for both ratios. E-mail me PeterZekert@Juno.com
Posted on: 2003/2/4 5:57
Re: 5 Speed Close Ratio transmission parts for sale
From Christchurch, New Zealand
Are these the "dog leg" gearboxes?
Do you know what the ratios are?
Where are you?
How much?
Cheers
Posted on: 2003/2/4 7:45
Re: I'm not sure what "Dog Leg" gearboxes are?
Matt, I need an "English-NZ-Austrailian-South Africa-America" dictionary, especially with car terms. The close ratio and ultra close ratio gear sets where sold as part numbers 32010-H7251P and 32010-H7220N for the F5C56A 5-speed transmissions. If anyone can help us, it would be appreciated.
Prices, for new gears I get $100 US and for used ones I get $50. All of this stuff is NLA (no longer available, an expression we use alot in Datsun racing.)
I also stock NEW 70mm stroke cranks for $300 US each and stock wet sump racing pans for both the 1200 and for the B210 at $500 US each. Peter
Posted on: 2003/2/4 19:33
From Wellington New Zealand
Hiya
Got any C/R parts for the F5C71 series boxes pref: non-overdrive.? These were the ones behind FJ, RB, some L series motors....
Posted on: 2003/2/5 2:51
"Dog leg" is this shift pattern:
R-2-4
1-3-5
I think the mid-70s B210 used these. The 1980 B310s used the standard pattern:
1-3-5
2-4-R
Peter, what's the latest on a-series forged piston availability? Club members have been regularly asking about those ...
Posted on: 2003/2/5 5:54
Re: F5C71 gearbox C/R gears
Sorry, I don't have any F5C71 close ratio stuff. Peter
Posted on: 2003/2/8 6:11
Re: Forged Racing Pistons, 76mm
I DO have ONE SET LEFT of the JE Forged Racing Pistons left, complete. They are $550 set, complete. 76mm bore, using the 19mm piston pin.
Otherwise, I will need to have 12 pistons ordered to do another order. Peter
Peter Zekert
105 Reading Ave.,
Maryland Heights, MO 63043
314 291-8441
cell 314 724-7098
Posted on: 2003/2/8 6:19
