#1 Turbo EFI Set up
boondy Posted on: 2007/5/30 3:21
I have a T28 turbo and manifold Ally inlet (round port) manifold with 60mm throttle body to suit A series, Injectors adjustable fuel reg Subaru water air intercooler and 12v water pump
Stinger ECU and Harness to suit, elec dizzy modded for turbo + other stuff
I have no time to put it my Ute
The wiring will need some sorting out I have the full stinger manual
I want around $1500 for all of it
I don
#2 Re: A15 + Turbo EFI Set up
BigD Posted on: 2007/5/30 5:34
Is the exhaust manafold round port too or Oval port ?? also has it got a J pipe or its a proper made manafold (straight to the turbo)
Interested to see pic's
#3 Re: A15 + Turbo EFI Set up
Tyrie Posted on: 2007/5/30 5:40
exhaust will be square port
#4 Re: A15 + Turbo EFI Set up
boondy Posted on: 2007/5/30 9:29
Its a 1 piece manifold made from steam pipe elbows the turbo bolts to it The round port head was on the engine, it must be off a 120y
#5 Re: A15 + Turbo EFI Set up
BigD Posted on: 2007/5/30 22:52
PM sent
#6 Turbo EFI Set up
boondy Posted on: 2007/6/28 2:33
Pctures added more can be emailed
#7 Re: Turbo EFI Set up
Talasas Posted on: 2007/6/28 2:44
Hmmm very intersting.
The dizzy "modified for turbo" meaning what - has the timing map for it been changed?
Also, is there a fuel pump and surge tank I see there?
I'd would like to see more pics please, PM me if you could, I'm very interested.
#8 Re: Turbo EFI Set up
TnPshow Posted on: 2007/6/28 3:40
A dizzy modified for turbo usually means the mechanical and vacuum advance has been disabled by locking the two shafts together.
#9 Re: Turbo EFI Set up
boondy Posted on: 2007/6/28 4:32
Yeah its locked but I was going to try and use the stinger to control timing but never got aroud to doing it
All of this gear was in a running Datto 1000 I have all of the gear here still but will separate. Im going to put turbo and stinger on Ebay later
#10 Re: Turbo EFI Set up
Talasas Posted on: 2007/6/28 4:44
So the Stinger is tuned for a 1000 and has all the sensors and plugs to suit injectors etc? Does it run well?
We are very interested in this if you are willing to ship the lot.
