Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Vanette Diff
Demojob
Posted on: 2003/3/14 11:11
Hey any of you guys use a vanette diff(H190)????
If so is it better then the ute diff?? As I'm debating whether to get one to correct the weirdness of having my front wheels sticking out, cuz of my stanza struts i installed. Cheers Damo
#2
Re: Vanette Diff
Lobster
Posted on: 2003/3/14 11:40
How much do your wheels stick out?
Have you got a pic? Just some mild flaring made mine fine.
#3
Re: Vanette Diff
b310gx
Posted on: 2003/3/14 11:42
i've seen a h190 in a 1200 coupe,but it increases the rear track by 50 mm.you just have to move the rear spring perches.you can get steel 4.11's or alloy 4.6's.you can either use front wheel drive offset wheels,or flare the guards.the coupe at datsun1200.com/modules/myalbum/photo.php?lid=948 has the same width housing,but a h165,if you look carefully you'll see the mags are front wheel offset.the front wheels are only on there for the photo,thats the wheel from the left rear on the front.
#4
Re: Vanette Diff
Demojob
Posted on: 2003/3/14 11:51
Sorry lobster I don't have pics my wheels don't stick out that much, just a little noticable, I'm getting flares for the front, I don't know if it will be very noticable then.\
I've got a set of front wheel drive wheels 16x7's :) As soon as my coupe is back on the road after I've finished everything to it, I'll take pis of it, for all Cheers Damo PS Should I really change from my ute diff, or just leave it as is???
#5
Re: Vanette Diff
1200rallycar
Posted on: 2003/3/14 14:56
i think h190 is 90mm wider actually
it has fatter axles and housing ect, ect but centres and brakes are interchangable with h165 diffs You can view topic.
