« 1 (2)
Re: e15et swapped into 1200
From adelaide
Def worth a go, i had an et turbo couple of years back, stock motor, t28, front mount, 2.5" exaust, microtech, extra injector etc and it realed 130rwkw @ 19psi, cheap power if you ask me! A series box will hate it! On a side note i guess you could hole saw the fire wall for dissy clearance and just resses it back?
Posted on: 2007/8/31 8:34
1200 restoration project moving slower than it actually is
From Coondle, WA Australia
A friend ralled the EXA with the E series motor, and the NA version of the head was rubbish, but the turbo head was aparently well designed. For a rally car, he said it was average, and he had difficult extracting any power out of it since he was limited in its mods. (It was the NA version not turboed)
Fix the dizzy with a crank angle sensor
Posted on: 2007/8/31 12:45
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
$150 - $200 bucks will get you distributorless ignition system called EDIS.
Posted on: 2007/9/1 4:06
From ACT
well if you have alot of patience then i should be able to help you out with this conversion in year or so's time. lol. already started gathering the parts for it
Posted on: 2007/9/1 8:28
« 1 (2)
