« 1 (2)
#11 Re: different Datsuns weight from factory
Tyrie Posted on: 2007/12/12 23:37
Mawler1 wrote:
it's not on the list but a 120Y 4 door sedan(auto) is 741kg
manual version is 675 Kg
you mean 775kg for the 4spd??
#12 Re: different Datsuns weight from factory
L18_B110 Posted on: 2007/12/12 23:40
beattie wrote:
240, 260, 280 What?
Z? 2+2 or 2 seater?
K?
C?
I think 2 seater Zs are around the high 800 mark, def under a ton. And i think the 2+2 is a little over a ton.
2 seater 240Z are 1080kg IIRC. and there ain't alot you can remove to make them lighter.
the 2 seat 260Z is heavier. no-one cares what the 2+2's weigh. we'd all rather forget they were ever made.
#13 Re: different Datsuns weight from factory
Demo Posted on: 2007/12/13 2:06
still would like the
260
280 weights if possible in any model
240 are fetching a good price cant find a good cheep project
also
whats the weight of a
a12 engine
manual box from factory
out of a 1200 ute (early 70s)
still need 2 13'' rims or something else that will be the same as a 180b stockie
around sydney area
#14 Re: different Datsuns weight from factory
Mawler1 Posted on: 2007/12/13 16:20
675Kg for the 4 speed
741kg for the auto
I belive that to be correct as I can lift a F4W56A and F4W60L with ease
It's a 3N71B I struggle with...
when The Defect III is complete I intend getting it weighed... just out of curiousity
just need 6 things to fix to have it drivable + glue back together the right hand taillight ring after I broke it today...
possibly planning fabricating some new ones using some thin alloy sheet (highly polished) using the mounting gaskets as templates and a few bolts to keep them restrained
#15 Re: different Datsuns weight from factory
Tyrie Posted on: 2007/12/13 23:51
There's no way a 120y sedan (auto or manual) weighed less than any of the 1200s.
The 1974 'Wheels' road test of the 120Y 4door sedan 4spd manual says it weighed 775kg.
#16 Re: different Datsuns weight from factory
Whorida Posted on: 2007/12/14 0:43
The rego papers for my ute say 690kg
#17 Re: different Datsuns weight from factory
D Posted on: 2007/12/14 5:15
Lightest Datsun ever is the late 50s feather around 450kg.
standard versions of the 1k
ute 615kg (no passenger sunvisor, radio or heater)
deluxe extra 15kg
2 door 625kg (no passenger sunvisor, radio or heater)
deluxe extra 15kg
4 door 645kg (no passenger sunvisor, radio or heater)
deluxe extra 15kg
coupe 675kg (has all the trimmings, goodies etc!)
My 2 door sedan with bumperettes and many other bits is just under 600kg.
My friend Al has a 58kg 1600cc vitara engine and sierra box and saved another 30kg. He is looking perhaps at a lightweight Winters diff to keep it that way and also lexan windows for the rear and eventually composite leaf springs to target the 550kg mark. The vitara engine will be bored for 1780cc using full sleeves and maybe boost.
#18 Re: different Datsuns weight from factory
Demo Posted on: 2007/12/15 0:38
whats the weight of a stock
a12 engine from a datsun 1200???
gearbox out of datsun 1200???
#19 Re: different Datsuns weight from factory
DimeDave Posted on: 2007/12/15 15:14
Gearbox weights
Comp 56 series 4 speed, 39lbs or 17.7kg
Stock 60 series 5 speed, 52 lbs or 23.6kg
#20 Re: different Datsuns weight from factory
DimeDave Posted on: 2007/12/15 16:01
Engine Weights, supposed shipping weight (I haven't confirmed)
A12 192lbs or 87kg
A14/15 205lbs or 93kg
« 1 (2)
