Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
T3 Pre- FAb'd Manifolds for CA18DET*** ?????
SAnt0s
Posted on: 2008/5/2 8:48
Greetings,
I am looking to see if you guys down under have or know of any places that sell pre-fab'd manifolds for our lil 1200's. I have a T04E that i will be running on my B110. and i am not looking to run a Ebay one. just checking my options before i commit to getting a custom one.
#2
Re: T3 Pre- FAb'd Manifolds for CA18DET*** ?????
rock1200
Posted on: 2008/5/3 0:23
You can always weld a t3/4 adapter onto you cast manifold. I did this years ago on my s13 and it worked well, cheap to do. Make sure you shot peen the weld though, other wise it has the potential to crack.
#3
SAnt0s
Posted on: 2008/5/3 2:55
We discussed that option too but with my 1200 its LHD, so the t25's hotside was already pressed againest the steering box and with the T04E it won't clear unless I stack washers on the motor mount to bring the motor up some....
#4
kegs
Posted on: 2008/5/3 3:37
a top mount manifold will remedy this use a t28bb as well goes very well with three inch exhaust
#5
SAnt0s
Posted on: 2008/5/3 4:24
Ya a top mount would work, but the other thing I found is the turbo wil have to be angled facing the 5 o'clock position if overloking the motor because now the brake master cylinder will cause issues with the downpipe....
#6
rupertscoupe
Posted on: 2008/5/3 4:43
is it internal or external wastegated?? i have a tubular manifold made as a low mount, it sits really close to the block so may work...but it hasn't got an outlet for an external wastegate
#7
SAnt0s
Posted on: 2008/5/3 5:40
Externally gated, I can have it modded for external....
Its easier for you guys since your box is on the other side...lol Any pics of your manifold? I'm in no rush since I have a BB T28 spec r turbo also... ;) You can view topic.
