compression
From durban, south africa
hey guys,
i did a compression test on my a-12 and it was 150psi. does that sound right?? should go higher to about 180psi, and what benifits will i have with my high compression?
many thanks
nicholas
Posted on: 2003/8/21 15:00
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: compression
From Mandurah WA
Well the main thing to watch out for when doing compression tests is the varry between cylinders should be no more then 20psi at most.
Higher compression means more combustion = more power
Posted on: 2003/8/21 15:09
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
Re: compression
Hi Nicholas, search for compression in the search box (found on the left side of the page). There was a detailed discussion about this a month or so ago.
I agree with Mazda626, but for specific numbers, the discussion had some interesting statements.
Posted on: 2003/8/22 20:08
