A15 turbo pistons
Quite a regular
From Finland
Can anyone tell me is there work number for a A15 (or A14) JE-pistons, for turbo use (Flat top would be good)?
Or do you know are there any other good pistons for turbo use?
I have destroyed already 2 motors, standard pistons are not strong enough.
I am using 1.4 bar boost.
Posted on: 2003/8/28 5:51
A14 Turbo Power
Re: A15 turbo pistons
From Melbourne, Australia
hi finn,
as you may have seen im going to be turboing an a-15 soon, could you please tell me all about your setup????
cheers mate
Posted on: 2003/8/28 5:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Warwick, QLD
Dude lower your boost am I right saying 1bar = 14.3PSI??? I can't remember it right. No stock pistons handle that much boost too well, flat tops will increase compression resulting in detonation, your best bet is going with forgies they could withstand a nuclear blast
Somebody please correct me if I'm wrong anywhere
Cheers
Damo
Posted on: 2003/8/28 6:22
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
conversion is correct, dunno bout the nuclear blast bit though
Posted on: 2003/8/28 6:25
1200 Coupe Rallycar
From Sydney
The forgies will be able to take the boost, but your block won't for much longer.
Also 1 Bar is 14.7psi so 1.4 bar is 20.58psi.
Posted on: 2003/8/28 6:34
Quite a regular
From Finland
The block can handle 2 bar boost at least, because I have already used it , the only broblem seems to be standard pistons which go broken in a middle of the piston rings
I only want to know is there already reasonbly cost and enough strong pistons for turbo use. (Wiseco, Je or something?)
Posted on: 2003/8/28 6:54
A14 Turbo Power
From Sydney
My JE's were around $300AUS each without rings.
From my dealings with turbo A-series, although they have an iron block, after being subjected to sustained boost levels above 1 bar they bores seem to be out of round. Resulting in massive amounts of blow by.
Posted on: 2003/8/28 7:13
From Little Rock, AR
Most companies in the US will sell custom forged pistons any way you like them for $80-150 per piston. JE is probly the most popular, just contact them from off the internet and see what they can do for you. You'll probably have to send in one of your stock pistons and measurements (combustion chamber cc's, etc). That's a lot of boost though! I'm surprised it's just the pistons breaking! I figured the rods and rod bolts would be the weak spot. Watch out when you get the pistons to finally hold up under that boost! I think the block will take anything you give it. Good luck!
-Andy
Posted on: 2003/8/28 14:10
Quite a regular
From Penrith, NSW
Boost DOES NOT hurt pistons! Heat & detonation does. fix these 2 problems & standard pistons will not break,just wear out.
Posted on: 2003/8/31 12:29
From Mudgee NSW Australia
Hi daniel welcome to the club.
Hows the little blue rocket going??
cheers Andrew
Posted on: 2003/8/31 12:40
If In doubt run more BOOST
